DAZ|Studio F.A.Q (Last Updated: 2025 Jan 22 11:25 pm)
I use topaz get just about any efect you want
with
http://www.irfanview.com/ free
You get better results then with toon shaders.
The
Artist that will fight for decades to conquer their media.
Perhaps stating the obvious here, but Studio does have a toon-style shader built in. I don't recall exactly where as I've customized my layout UI quite a bit, but in the standard UI when you go to hit 'render' in Studio 4, the pop-up box that has some values for normal also has a drop down tile where you can select 'Cartoon'. Studio 3 had this as well, slightly different orientation. I'm sure its more easily accessible under Render Settings in the Render tab.
The same can be done quite easily in post, as RorrKonn mentioned. I've never used those particular programs, but Gimp has a plethora of toon and comic book effects that are pretty easy to make what you want.
crimsonworx.com; free ebooks and previews
I've bowed down to facebook: https://www.facebook.com/crimsonworx
There pretty kool & afordable,might want to check them out.
So far I got Detail-2 $40 & Clean-3 $30.
Simplfiy & Adjust ect ect still on my to get list.
There's a few app's thay work with ,sadly not gimp maybe one day.
http://www.topazlabs.com/support/kb/index.php?View=entry&EntryID=17
The
http://dictionary.reference.com/browse/User+interface?s=t&ld=1031
The .jpg was Tweaked with Topaz.
If you got Topaz not that you would need these.
Just making sure you know about them.
zBrush $700.00 is a lot more then just shaders .
The Baddest CGI app ever conceived.
Has some kool shaders.
http://www.pixologic.com/home.php
Blender the Free ,main CGI app.
The
Hi,
Does anyone know if there are any tutorials available for comic or cartoon style renders in daz studio, please?
