Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 15 2:13 am)
i applied the texture to both texture and trans boxes, make sure the trans min and max are 100% and make sure the texture is on the eyebrows, the uppereyebrows and the lashes. For some reason i have two listings for eyebrows in my Vicky model so just make sure all eyebrow and lashes are same texture. Also i found that if you select the head and look at the default skin colour for it and add it to custom colours and then change the eybrows etc to same default colour you set as a custom. Now im confused lol, loads up poser to check. rodpanther
no, here's the break down 1. apply texture map to the eybrows (match to face for everything) 2. apply the transparency map to the upper eyebrows & eyelashes (you can apply the tex map if you want, I usally just set the object color to black or dark brown) trans min & max for upper eyebrow = 100%, trans falloff = 0%
Use transparency at 100% only on the Upper Eyebrows, not on the Eyebrows (the base under the upper eyebrows). If you put transparency on the base eyebrows, you'll get two big black holes where the eyebrows are and she'll look like Groucho Marx. Transmap ONLY the upper eyebrows and you're set. Hope that helps clarify. I had the same problem at first, so you're not alone. Melanie
I downloaded the upperbrow trans freebie from this site for Vicky and I can't get it to work at all!! I followed the instructions in the zip file but still no luck. I was hoping to get some suggestions from you guys that actually got it to work. Thanks a bunch!
