DAZ|Studio F.A.Q (Last Updated: 2025 Jan 20 7:19 pm)
If you're running Windows, there is a 3D_Bridge_User_Guide.pdf that is installed in C:Program FilesDAZ 3DDAZStudio4docsPluginsPluginNotes if you're running the 64 bit version of DS4 or C:Program Files (x86)DAZ 3DDAZStudio4docsPluginsPluginNotes if you're running the 32 bit version of DS4.
There is no mention of Photoshop Elements support in the DS4 version of the bridge guide. On page 1 is states:
Photoshop Versions Supported
Macintosh
PC
Installation - Macintosh & Windows
Versions of Photoshop the 3D Bridge works with:
The two statements don't agree, so I'm not sure which one is accurate.. LOL
In order to get the 3D bridge working with DS3A again, you probably need to uninstall the DS4 bridge and re-install the DS3A bridge that was working with your PSE7 install.
Hi,
I had D3A and use PSE 7 and the bridge worked perfectly. I have Daz4 pro now and I can't get the bridge to work at all. It no longer works in D3A now either :(
Has anyone else had the same problem - and been able to find a fix for it lol ?
Thanks in advanced for any help.
