Tue, Jan 21, 11:59 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 4:30 pm)
Subject: Scaling conundrum
WhimsySmiles ( ) posted Wed, 18 July 2012 at 11:15 AM · edited Fri, 17 January 2025 at 7:42 AM
I've run into a little problem with scaling that maybe someone can help out with, if there's anyone good at math.
I'm scaling a character to 95% of its original size, to refit dynamic clothing, then I want to rescale the clothing back to the original size of the character again..  Problem is I don't know how to get this number.  Anyone good with math who can help me out how to calculate this?
Thanks!
basicwiz ( ) posted Wed, 18 July 2012 at 11:29 AM · edited Wed, 18 July 2012 at 11:30 AM
Try 105.5. It'll get you close enough, methinks.
Actually, when I do this, I tend to just eyeball it.
Also, have you tried just scaling the clothing item to the character? That would seem simpler, depending on the effect you are going for.
cspear ( ) posted Wed, 18 July 2012 at 11:36 AM
The maths is to divide the size or scale you want (100) by the size/scale it is now (95) = 1.052631578947368
(then multiply by 100 if you want it as a percentage: 105.2631578947368, but you should be able the shift the decimal point two places in your head).
PoserPro 11 - Units: Metres
Adobe CC 2017
3doutlaw ( ) posted Wed, 18 July 2012 at 12:23 PM
...and make sure you go out to the 13th decimal place, 'cause that extra 0.0000000000008 is really what makes the difference!  :tongue1:
WhimsySmiles ( ) posted Wed, 18 July 2012 at 1:31 PM
Alright thanks for the tips, should get what I need!
MistyLaraCarrara ( ) posted Wed, 18 July 2012 at 2:02 PM
Quote - ...and make sure you go out to the 13th decimal place, 'cause that extra 0.0000000000008 is really what makes the difference!  :tongue1:
was that a Johnny Dep movie?  13th decimal place
dadt ( ) posted Thu, 19 July 2012 at 4:59 AM
Actually, there is no need to scale the dynamic clothing.If a dress fits a figure which is scaled at 100% and saved as a smart prop,then if it is applied to a figure which has been scaled down, it will automatically rescale to fit.
WhimsySmiles ( ) posted Thu, 19 July 2012 at 11:03 AM
Yep, aware of that. :)  This howerver is a special refit of pants that I have made for V4, that I am refitting to M4 in another 3d program, while preserving the UV coordinates.  I want to present them in normal 100% scale as the props are loaded, with constrained groups intact. This has worked fine, I just needed a formula to get the scaling just right.
Quote - Actually, there is no need to scale the dynamic clothing.If a dress fits a figure which is scaled at 100% and saved as a smart prop,then if it is applied to a figure which has been scaled down, it will automatically rescale to fit.
