Wed, Jan 22, 12:18 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 10:04 am)
Subject: Wall materials
Sheedee ( ) posted Thu, 19 July 2012 at 1:08 PM · edited Wed, 22 January 2025 at 12:16 PM
Hello;
Can some one please tell me where i can find shiny materials to apply to walls...like shiny tiles and stuff like that?...or if there is a room prop any where with shiny walls?...
Thanks.
PS. i use Poserpro 2012
ghostman ( ) posted Thu, 19 July 2012 at 1:23 PM
Comes with the program. In the prop folder you have walls to build a room and in the material folder you have materials for it.
"Dream like you'll live forever. Live like you'll die tomorrow."
Join PoserLounge Chat
SamTherapy ( ) posted Thu, 19 July 2012 at 1:30 PM
Use the Tile node on the One Sided Square.  Play with the tile sizes, colours and so forth to get the result you want.
vilters ( ) posted Thu, 19 July 2012 at 1:37 PM
Specular will bring you shine.
Blinn will bring you shine
Glossy will bring you shine.
A bump/displacement map, the tile node, and yes the brick node give you all what you can dream off for a wall.
Sheedee ( ) posted Thu, 19 July 2012 at 2:37 PM
Sorry to be such a bother people, i loaded the one sided square...but where can i access its nodes?...like the tile node for example...i went to the material room and then in the tab advanced, but i cant see the nodes.
thanks.
SamTherapy ( ) posted Thu, 19 July 2012 at 2:48 PM
You have to connect something to the One Sided Square.  Click on the little Socket thing at the side of Diffuse_Color, hold the mouse button and drag it out.  You'll see a cable and a popup.  Select Tile from the popup list.
You'll then have a node to work on.  You can change the tile colours, sizes and various other properties.
You can add a black and white version to the Bump or Displacement channels, and maybe play around with Alternate_Specular to give your tiles a glossy look.
Addendum:  You should always use Advanced mode in the Material Room.  The other is for numpties.
vilters ( ) posted Thu, 19 July 2012 at 2:54 PM · edited Thu, 19 July 2012 at 2:56 PM
Click on the small loudspeaker that is behind all options in the left colon. Drag to the right A menu opens See screengrab.
Read the manual for what does what and goes where.
oesp, X-posted with Sam
Please Shedee, reduce font size?
Thanks, makes it hard to read this way.
