Wed, Feb 19, 11:43 AM CST
Forum Moderators: RedPhantom
Subject: pathetic win7 question, how to search within files?
MistyLaraCarrara ( ) posted Thu, 19 July 2012 at 5:18 PM · edited Wed, 19 February 2025 at 11:41 AM
i'm trying to search my readme files for 'hair'
i can't find anything for an advanced search to say search within files.
the win7 help files say search assistant is gone.
Thanks
Blackhearted ( ) posted Thu, 19 July 2012 at 5:32 PM
win7 searches in SOME types of documents automatically
when i put a search string in, it will pull up filenames that have nothing to do with the search string, but have a 'preview' of a snippet of text within the document that has that search string.
works for:
docx
rtf
hmt/html
etc
it also seems to do it for .txt files, but doesnt show the paragraph preview - the files just appear in the search.
AFAIK this is default windows 7 behavior, you may have disabled it somehow?
im using win7 ultimate x64
Lully ( ) posted Thu, 19 July 2012 at 5:39 PM
isnt there a deep search when you add the text in the right hand corner box in windows explorer, I'm sure that searches within readme files.
Tools:- Win10, Dell XPS8900, ZBrush, Marvelous Designer 11, Hex 2, PSP8. PSP 2019 Ultimate, DAZ Studio, Affinity Photo, Affinity Designer, Filterforge 11, flowscape,  Classic UVMapper, and several headache tablets.
Blackhearted ( ) posted Thu, 19 July 2012 at 5:41 PM
^i should have mentioned that thats where im entering the search terms.
MistyLaraCarrara ( ) posted Thu, 19 July 2012 at 6:20 PM
i don't see a deep search.  i have the home version.
the custom search shows me check boxes for folders.  it's not in the filters.   this is like the ms twilight zone
wimvdb ( ) posted Thu, 19 July 2012 at 6:29 PM
In the Start button there is a field wich says "Search program and files"
Fill in your search term and then click "See more results" and a new window will open with the term in its name or in their content.
3doutlaw ( ) posted Thu, 19 July 2012 at 10:46 PM
Notepad++ has a "Find in Files"  😊
BunkyBucket ( ) posted Thu, 19 July 2012 at 11:10 PM
You might want to take a look at this search tool it is amazingly fast.
http://www.voidtools.com/
donquixote ( ) posted Fri, 20 July 2012 at 1:03 AM
Not pathetic at all. I've found Win7 search very undependable, i.e., quite inferior to previous versions of Windows ... just my opinion I guess ...
Lully ( ) posted Fri, 20 July 2012 at 1:05 AM · edited Fri, 20 July 2012 at 1:06 AM
> Quote - i don't see a deep search.  i have the home version. > > the custom search shows me check boxes for folders.  it's not in the filters.   this is like the ms twilight zone
mine is home premium so should be the same, open windows explorer and the field is shown in the pic
if after you search if you right click on the list of items its found you can sort into certain orders, ie date, type of file
donquixote ( ) posted Fri, 20 July 2012 at 1:13 AM
May be fast, but it doesn't search file contents.
Quote - You might want to take a look at this search tool it is amazingly fast.
wimvdb ( ) posted Fri, 20 July 2012 at 3:50 AM · edited Fri, 20 July 2012 at 3:51 AM
Quote - May be fast, but it doesn't search file contents.
That depends on your indexing options. If you have it at default, Windows Search searches the content of many different filetypes amongs others .txt
It even works across your own local network.; So if you have a share to another windows 7 machine, a query on your own machine onto that share will use the index of the other machine to get the result.
I find it very dependable and fast and use it all the time.
cspear ( ) posted Fri, 20 July 2012 at 4:36 AM
Head over to Ralf Sessler's site (Dimension3D of Morphing Clothes fame): he has a really good Windows search tool (for free).
PoserPro 11 - Units: Metres
Adobe CC 2017
3doutlaw ( ) posted Fri, 20 July 2012 at 8:39 AM
Notepad++ is also free, and a really good text editor as well!  :)
@wimvdb, are you saying that "Everything" by Void Tools does search contents?  Can you explain how?  I use it all the time, but it has never done this.
wimvdb ( ) posted Fri, 20 July 2012 at 8:46 AM
Sorry, confusion in my part. Windows search does search content.
I have not experience with Void Tools, never had any need to use something different as the standard search in windows
3doutlaw ( ) posted Fri, 20 July 2012 at 8:57 AM
Oh, OK, no probl, was thinking I was missing out on a cool feature.  Everything uses the Windows change record's to find/index, so it is lightning fast...but it finds files only, I believe.  Not really on topic for the question, but a good tool, nonetheless!
Lully ( ) posted Fri, 20 July 2012 at 11:34 AM
Done a test on searching content of a text file.
I tend to use this all the time and nearly always find it, other times its because ive not put the search term in right :blushing:
MistyLaraCarrara ( ) posted Mon, 23 July 2012 at 3:09 PM
turns out the indexing was the problem.  i had to go to advanced properties for my readmes folder and changed the indexing setting to include content, then had to give win7 time to finish the indexing.
thank you everyone for the help    hugs{{
foxylady1 ( ) posted Mon, 23 July 2012 at 4:49 PM
I learned a few things from this thread, so thank you for asking MLP.
NanetteTredoux ( ) posted Wed, 25 July 2012 at 1:58 AM
Copernic desktop search - google it.
Poser 11 Pro, Windows 10
monkeycloud ( ) posted Wed, 25 July 2012 at 3:42 AM · edited Wed, 25 July 2012 at 3:43 AM
Yeah indexing is the key with Win7 and Server 2008 / R2...
It should search files with text type content by default... i.e. the non-binary Poser file formats etc?
Not sure about Win7, but certainly for server it's necessary... or was... to install additional content filters for MS Office docs:
http://www.microsoft.com/en-us/download/details.aspx?id=17062
Or OCR'd tiffs...
http://technet.microsoft.com/en-us/library/dd755985%28v=ws.10%29
...its also possible to write these using the Search service SDK, e.g. for .DWG:
http://www.ifiltershop.com/downloads/dwgfilter/readme.html
...and others:
cheers 😉
