win7 searches in SOME types of documents automatically
when i put a search string in, it will pull up filenames that have nothing to do with the search string, but have a 'preview' of a snippet of text within the document that has that search string.
works for:
docx
rtf
hmt/html
etc
it also seems to do it for .txt files, but doesnt show the paragraph preview - the files just appear in the search.
AFAIK this is default windows 7 behavior, you may have disabled it somehow?
im using win7 ultimate x64
isnt there a deep search when you add the text in the right hand corner box in windows explorer, I'm sure that searches within readme files.
Tools:- Win10, Dell XPS8900, ZBrush, Marvelous Designer 11, Hex 2, PSP8. PSP 2019 Ultimate, DAZ Studio, Affinity Photo, Affinity Designer, Filterforge 11, flowscape, Classic UVMapper, and several headache tablets.
i don't see a deep search. i have the home version.
the custom search shows me check boxes for folders. it's not in the filters. this is like the ms twilight zone
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
mine is home premium so should be the same, open windows explorer and the field is shown in the pic
if after you search if you right click on the list of items its found you can sort into certain orders, ie date, type of file
May be fast, but it doesn't search file contents.
Quote - You might want to take a look at this search tool it is amazingly fast.
Quote - May be fast, but it doesn't search file contents.
That depends on your indexing options. If you have it at default, Windows Search searches the content of many different filetypes amongs others .txt
It even works across your own local network.; So if you have a share to another windows 7 machine, a query on your own machine onto that share will use the index of the other machine to get the result.
I find it very dependable and fast and use it all the time.
Head over to Ralf Sessler's site (Dimension3D of Morphing Clothes fame): he has a really good Windows search tool (for free).
PoserPro 11 - Units: Metres
Adobe CC 2017
I tend to use this all the time and nearly always find it, other times its because ive not put the search term in right :blushing:
turns out the indexing was the problem. i had to go to advanced properties for my readmes folder and changed the indexing setting to include content, then had to give win7 time to finish the indexing.
thank you everyone for the help hugs{{
Yeah indexing is the key with Win7 and Server 2008 / R2...
It should search files with text type content by default... i.e. the non-binary Poser file formats etc?
Not sure about Win7, but certainly for server it's necessary... or was... to install additional content filters for MS Office docs:
http://www.microsoft.com/en-us/download/details.aspx?id=17062
Or OCR'd tiffs...
http://technet.microsoft.com/en-us/library/dd755985%28v=ws.10%29
...its also possible to write these using the Search service SDK, e.g. for .DWG:
http://www.ifiltershop.com/downloads/dwgfilter/readme.html
...and others:
cheers
i'm trying to search my readme files for 'hair'
i can't find anything for an advanced search to say search within files.
the win7 help files say search assistant is gone.
Thanks
