Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 5:58 pm)
Great news! Thank you so much for your efford and contribution! It is a must have tool!
Thanks. Been looking forward to this.
Looks like you have Poser Display Unit (PDU) = PNU, and the displacement amount was supposed to be in inches.
Switch your PDU to inch and try again.
Did I do something wrong when I placed it in my Python folder???? It says that V4 is an unsupported figure.
Weapons of choice:
Hello,
sometimes when EZSKin says "unsupported figure" it's due to saving a morph-loaded character back to the library and reloading it. In this case the geometry file name would change. You can see that with the info script. Try loading a fresh V4 character.
Thanks Snarly, for the great work! I will try the 2.0 version today.
Best regards,
Michael
Figure definitions need to be imported.
I forgot about that, too, and thought the problem was due to my renaming Victoria 4 to my character's name in the Properties tab. But once I imported the defs, all was well.
______________
Here's a replacement effects file. Remove the '.txt' bit at the end, of course.
Free stuff @ https://poser.cobrablade.net/
Here's an updated 'Wet Skin' effects file (remove the '.txt' bit as usual). I think it looks a little better and has reflection too.
Transparency and refraction aren't going ot do any good - what is there to see through the 'water'? There's no skin beneath the water because the drops are just the skin with some bump applied...
I'll do a couple more effects over the next few days.
Release Candidate 4 will be posted soon. I'm letting the beta testers play with it for a day or so first, then I'll let everyone have a go. Hopefully that will also be the final version!
Cheers.
Snarlygribbly I bought a new character from the marketplace here EchuDr by Dinoural,
when I load him and use EZSkin (The new version 2) and I apply a pose to him,
his eyes disappear! I thought maybe it was a problem with the figure, but if I
load him and don't use the EZSkin script he poses fine and no eyes disappearing.
His eyes are there in the zero pose after using the script, but any pose and
poof their gone. Thanks for any ideas on what may be causing the problem.
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
System Ram: 8GB
Ok that worked for me, I don't know what I did wrong. Thank you for your help and a great script!
System Ram: 8GB
Snarlygribbly, I just installed the new download and when I try and run the script it says it doesn't work with my version of poser. I am usin P9 with all the latest updates, and the other version worked fine for me.
System Ram: 8GB
Quote - Snarlygribbly, I just installed the new download and when I try and run the script it says it doesn't work with my version of poser. I am usin P9 with all the latest updates, and the other version worked fine for me.
What is the build number of your version of Poser?
EZSkin v2 is looking for build 21462 or later, i.e. SR2.1
You're too quick on final. I only just started testing.
On Eyes Tab, in Reflect amt.
*) I cannot type 100 - I have to type 99 then spin up one more step.
*) Backspace key, instead of removing a digit, passes through to Poser and attempts to delete my figure.
Actually seems like backspace does not work in any of your numeric inputs.
Nor delete.
9.02.21214 is the version numer on the screen when I start poser, and unless I missed an update, I am sure I installed sr2
System Ram: 8GB
Quote - You're too quick on final. I only just started testing.
Nor delete.
This is weird.
Not only has no-one noticed that in all the testing (!), but that behaviour also appears to be the case in the oldest version of EZSkin that I've kept (v1.0.00 beta)!
At first I wondered if something had changed in a recent build of Poser, but no - in build 16510 with EZskin v1.0.0 the same thing happens.
I'll investigate ...
Quote - 9.02.21214 is the version numer on the screen when I start poser, and unless I missed an update, I am sure I installed sr2
You missed an update.
That build is SR2
EZSkin now requires SR2.1
It's confusing because the SR2.1 is still called SR2 on SM's website. Just download it and install SR2 again and you'll be good to go.
Snarlygribbly, I just checked and the update I installed to my poser 9 was sr2, I just checked Smith Micro and somehow I missed there is an sr2.1, so I am downloading that now and will see if that fixes my problem of not being able to use the EZSkin script. Thanks for your patience ;o)
System Ram: 8GB
All is fine now, I have the latest update! Thanks
System Ram: 8GB
Quote - Again...one more plea to SM to include the date on their service releases like EVERYONE ELSE in the world....lol.
It's even weirder than that. They don't use the second number.
Release 9, SR2.1 you would think, would be
9.2.1
Nope
It is
9.0.2.XXXXX
Where XXXXX is how many official builds they have done since they began counting - years ago. They have no way to show SR2.0 versus SR2.1 because they refuse to use the second number.
I have 9.0.3.22231
heh. I should have mentioned that earlier. I noticed that delete issue right away when I started using the previous version. Sorry.
______________
HAHA!
Snarly is indeed the epitome of Snarly's amongst the Gribblys! Never a better Gribbly have I encountered! :-)
Thank you Snarly. You are indeed a snarly among gribblys ;)
That's a compliment. I think....
Wow. This is awesome.
Being able to save a preset is excellent... but the new integral figure definitions are so easy to use.
I was able to set up a definition for the mildog, in a scene I'm doing, in about a minute this morning, before dashing for my bus to work.
I would never have gotten round to hand typing the XML for that figure.
I look forward to exploring the further possibilities.
I note it can do hair props now. Which is great. Is there a way of applying it to clothing props and clothing figures too?
Many thanks for all your hard work Snarly. This is fantastic!
Cheers
Quote - heh. I should have mentioned that earlier. I noticed that delete issue right away when I started using the previous version. Sorry.
LOL :-D
I was amazed when BB pointed it out. All those hundreds (thousands?) of users and all the beta testing and no-one's mentioned it until now!
My own way of working is to highlight the entire number and type in the replacement value, so I never came across the problem.
So easy to fix too! Doh!
EZSkin v2 is nearing completion.
It requires Poser Pro 2012 or Poser 9 with Service release 2.1 installed to run
Release Candidate 3 of the script (without any documentation yet) is available for download at:
ESKin v2 download
A user guide is currently being prepared with the help of basicwiz.
I'm hoping to release the final, documented version in about two week's time.
If you do decide to try the undocumented script, please post any problems found to this thread. If you make any cool renders using EZSkin we'd love to see them, and might ask permission to use them in the user guide :-)
Thank you,
Snarly
