Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 25 1:55 am)
You're right, Phil, I did misunderstand. But I never even considered using a "grandchild" before. As I said, I thought all subs had to be directly under the Pose directory. So I went back and went through every Pose "child" and I did find some "grandchildren". I removed 'em all and...still no luck. I cannot access any Pose sub-folders that begin with any letter after "P". I did check each of the main categories under Libraries and found that I have: Character 287 "children" or subfolders (not sure I'm grasping the concept unless a "child" is what I would call a sub-folder and a "grandchild" is a sub-sub-folder. Face 95 Hair 49 Hand 16 Pose 357 Prop 290 So I've got a LOT of children under Pose. I don't have this problem with Character/Figure nor with Prop, so I'm still wondering if Poser can only handle a certain number of "children" for each category. If you've got any further thoughts on this I'd really appreciate your help. Thanks, Doc
Perhaps you should try moving a number of your children and see if you can then access the ones beyond "P" If that works, slowly add them back in until you find the limit (assuming that is the problem). Then you can decided how to combine some of your children, when you know how many you have to limit it to.
I've posted about this before, but now I have more specifics on the problem. I cannot load any Pose files from any "sub-directories" that begin with anything after "P". For example, let's say I open the Poses panel, click on the little arrow that shows all "sub-directories" available and I go to "Pose Sets"...no problem. But if I try to open anything that begins with "R", like "Rex Set" or "Romel"...it jumps back up to one of the folders (sub-directories, whatever) at the top. At first, I thought my mouse might be wacky. So I stopped using the mouse and used the keyboard to scroll and select (it's faster anyway). But I still cannot open any of the folders that begin with letters after "P", like R, S, T, etc. Is there a limit on how many sub-folders you can have under Figures or Poses, etc.? I'm only having this problem with the Poses section. I'm using PPP. Thanks in advance for any help. Doc
