Quote - i don´t have enough disk space on hard drive
I have a similar problem, only it's money that I'm short of!
As a temporary measure, see if you can move some data files to to CD/DVD, that may give you enough free space to defragment, which may give you a little more space in you have not dedefragment fro a while. Also empty the Recycle bin, clear your browser cache, cookies, and Windows Temp folder. See if you can compress some files. Specific to Poser, set your 'Max cached renders' to a low number like 2. Also set a low 'Max undo level'.
the problem is not the render... the problem is that i can´t change anything.
for example the texture of a shirt...if i open it choose it for new tex, i can´t confirm it.
it hangs immediately.
i have 20 gb now and sometimes 25 then it works again..but with my older pc it worked with less space too...i don´t get it ;'(
Do you have the latest update? SM does still have it available. If I remember correctly, p7 would hang or crash if your hd was fragmented. If you haven't done so latly, try defraging. I had no trouble using p7 when my old hd was down to 20 gig or less. Also check your available memory. If there is memory swapping, you'll need extra hd space.
couple of things that havn't been sugested, move your windows swop file to D: drive, that will free up a bit of space on C: (after defragging D: , defrag C: after moving swop file)
and if you have vista/win 7 you can have a usb memory stick plugged in and use it as an extra swop file, google readyboost for details
Download "Advanced System Care free" from iobit
Version 5.3 is the latest, or try the 6.1 beta version
Let it run several times in deepcare mode and it does wonders to older or lower end PC's.
I run it on all my systems (7) to keep them clean.
it was the first app I installed on my i5 quad and my i7 hyperquad also.
You will be surpriced at how much better a clean PC runs.
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
i don´t have enough disk space on hard drive, so i can´t even change a texture.
if i can choose ok or cancel poser 7 hang and thats it
i have 20 GB of diskspace on c:
and about 200gb on my installed drive D
what to do?
