Fri, Nov 22, 2:02 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: ok i'm gonna learn python. which version should i use?
dorkmcgork ( ) posted Fri, 27 July 2012 at 6:17 PM · edited Fri, 22 November 2024 at 1:55 PM
i have poser 2010, but i want my python to work for 2012 too.  the python page at http://wiki.python.org/moin/Python2orPython3 hasn't been updated since 2010 it seems
my python shell says 2.4.2
any recommendations?
gratzi
o also...will the python i install from the site change the python that poser is running under or is that version secure?
go that way really fast.
if something gets in your way
turn
PhilC ( ) posted Fri, 27 July 2012 at 6:31 PM
Poser 8/Poser Pro 2010 uses Python 2.4
Poser 9/Poser Pro 2012 uses Python 2.7
There is not a lot of difference between them. The later Poser version has some extra methods mainly to handle weight maps. If you write a script for Poser 8 it will most likely run in Poser 9 also.
Gareee ( ) posted Fri, 27 July 2012 at 6:36 PM
Burmese.
dorkmcgork ( ) posted Fri, 27 July 2012 at 6:52 PM
thanks phil!
turn
markschum ( ) posted Sun, 29 July 2012 at 6:20 PM
you can install python without impacting Poser python at all. However the Poser methods wont work outside of poser.
sandman_max ( ) posted Sun, 09 June 2013 at 8:41 AM
I'm working with PP2014 but I've heard that it uses the same verison of Python as PP2012.  It looks like last version of Python 2 was v2.7.5.  Is that ok?  I'm guessing I should stay away from Python 3?  At least if I want to program for Poser...
markschum ( ) posted Sun, 09 June 2013 at 3:39 PM
why run a seperate python ?  I code in notepad ++ and run from Poser.
  None of the poser methods work in a standalone python install.
Just watch using any python which is flagged in the manual as deprecated.
I have python 2.4, 2.7 and 3 installed and they do not conflict with each other or Poser.
sandman_max ( ) posted Sun, 09 June 2013 at 6:10 PM · edited Sun, 09 June 2013 at 6:12 PM
I just want to make sure I have the option to test syntax in a non-poser environment so I can tell whether I'm making a Python mistake or a Poser mistake.  I know at some point I'm going to start coding in either C++, C# or Perl and be banging my head on the desk trying to figure out what's wrong.  And for the learning experience.  Thanks for the info.
Fenier ( ) posted Tue, 11 June 2013 at 10:25 PM
Code that works in Python 2x may not work in Python 3, and vice versa as Python 3 was a fairly major rewrite.
Poser specific methods will not work outside of Poser, so will throw errors when used outside of a Poser enviroment.
The other languages you mention all have very specfic quirks, C# would be OK if you only plan to code on Windows, while Perl favors UNIX/Linux.   C++ can be used on either system and is commonly the lowest language a lot of code is written in such as game engines.
