Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
I just want to make sure I have the option to test syntax in a non-poser environment so I can tell whether I'm making a Python mistake or a Poser mistake. I know at some point I'm going to start coding in either C++, C# or Perl and be banging my head on the desk trying to figure out what's wrong. And for the learning experience. Thanks for the info.
Code that works in Python 2x may not work in Python 3, and vice versa as Python 3 was a fairly major rewrite.
Poser specific methods will not work outside of Poser, so will throw errors when used outside of a Poser enviroment.
The other languages you mention all have very specfic quirks, C# would be OK if you only plan to code on Windows, while Perl favors UNIX/Linux. C++ can be used on either system and is commonly the lowest language a lot of code is written in such as game engines.
i have poser 2010, but i want my python to work for 2012 too. the python page at http://wiki.python.org/moin/Python2orPython3 hasn't been updated since 2010 it seems
my python shell says 2.4.2
any recommendations?
gratzi
o also...will the python i install from the site change the python that poser is running under or is that version secure?
go that way really fast.
if something gets in your way
turn
