Fri, Jan 24, 12:53 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: Import background picture in PP2012
helderres ( ) posted Mon, 06 August 2012 at 12:02 PM · edited Fri, 24 January 2025 at 12:51 AM
I'm having problems importing background images on Poser Pro 2012 and I need your help.
I have to render images on Poser Pro 2012, with dimensions 2400x1600 px and when I try to import image from the same dimension, (2400x1600), the PP2012 shows a window asking me if I wish to resize my document window to match the imported image.
By choosing "Yes" or "No" the background picture always doesn't match on the screen of Poser.
So, what I want your help to solve this problem.
bagginsbill ( ) posted Mon, 06 August 2012 at 12:43 PM
When the new UI with docking windows was introduced, some of the older stuff relating to the document window size was a little screwed up.
The important thing is not your document window size, but rather your render dimensions.
Explicitly set your render dimensions to exactly 2400 by 1600 and just ignore that dialog.
helderres ( ) posted Mon, 06 August 2012 at 1:19 PM · edited Mon, 06 August 2012 at 1:22 PM
Thank very much for your help.
Then, when the dialog box appears I must to close it and proceed rendening?
bagginsbill ( ) posted Mon, 06 August 2012 at 1:22 PM · edited Mon, 06 August 2012 at 1:22 PM
Say NO, set your render dimensions to 2400 by 1600. After that you can render at any dimensions you like.
vilters ( ) posted Mon, 06 August 2012 at 1:23 PM
Or load a prop, or square.
Set its dimentions to something like 240% in X and 160% in Y.
Load your background texture to that.
Then position as required for your render.
If you need shadows, you will have to play with the Ground plane and set it to shadow catch only in the material room.
happy posering
helderres ( ) posted Mon, 06 August 2012 at 1:26 PM
But I've done this way (responding “no”) and after rendening in 2400x1600), the image that I imported not filled the entire screen of Poser.
Unfilled side tracks appear.
toastie ( ) posted Mon, 06 August 2012 at 1:41 PM
Quote - But I've done this way (responding “no”) and after rendening in 2400x1600), the image that I imported not filled the entire screen of Poser.
Yes, same happens to me. The size doesn't quite match (even though the pixel size is set to be identical) and I get a gap along one side in the final render.
bagginsbill ( ) posted Mon, 06 August 2012 at 3:54 PM
I don't get a gap.
What version are you running?
helderres ( ) posted Mon, 06 August 2012 at 6:27 PM
I using Poser Pro 2012 with Windows 7 64 b, 16Gb RAM and AMD Phenom II X6 1100 Processor.
When I click "Yes" or when I click "No" de final result is the same.
You can see in the image attached.
vilters ( ) posted Mon, 06 August 2012 at 7:09 PM
For starters, your ground plane is still in the way.
It should be set at shadow catch only (if you need shadows).
Otherwise toggle ground plane completely OFF.
Only then will you be able to set your scene and see where the background inmage is exactly.
It works here.
bagginsbill ( ) posted Mon, 06 August 2012 at 9:06 PM · edited Mon, 06 August 2012 at 9:08 PM
Quote - I using Poser Pro 2012
Poser has had 3 updates. You can't just say Poser Pro 2012.
Which version - Original, SR1, SR2, SR2.1?
Since you did not say, I'm going to guess you don't know about updates and have an old version. There's no use trying to diagnose a problem that was fixed already. If you don't have SR2.1 get it.
toastie ( ) posted Mon, 06 August 2012 at 9:25 PM · edited Mon, 06 August 2012 at 9:27 PM
Mine's PP2012 SR2. I've downloaded SR2.1 but haven't installed it yet, so can't say yet whether this will still happen after. At the moment though I'm rendering images at 2400x3000px with a background image of exactly the same dimensions and I get a small gap of about 20px down the right hand side (occasionally along the top instead). It's not a big deal, I just have to remember to crop the render afterwards.
Ground plane is always off btw.
FutureFantasyDesign ( ) posted Mon, 06 August 2012 at 11:21 PM · edited Mon, 06 August 2012 at 11:23 PM
helderres, I import backgrounds all the time, and my set up, except I have an nvidiaGTX560, is identical to yours. Set the preview window for 1200 x 800,  import the 2400 x 1600 size and the image will load and fit fine. Render at the 2400x1600 size. Oh I also undock my preview window when I load the background to be sure it covers the entire area. Once you are assured of that redock, and just add your characters and props, position and render.
I always split the image size in half for the preview dimensions (*you still load the full size). Be sure to uncheck the "constrain aspect ratio" until you reset the render size, then recheck it and save for this render. See the screen shot for info on the corrections! ;)  I hope this helps you!
~A~
Is there water in your future or is it being shipped away to be resold to you?
Water, the ultimate weapon...
www.futurefantasydesign.com
helderres ( ) posted Tue, 07 August 2012 at 12:01 AM
Thank very much all of you for your help.
I tried the guidance of futurefantasydesign and it works perfectly.
Thank everybody for your Attention and patience.
Have a nice day.
FutureFantasyDesign ( ) posted Tue, 07 August 2012 at 10:58 AM
You're welcome! It is weird if you set the size in the preview to match the background I always got a warning that the image was too large to load, so I had to find my own work around. If ever I can help you out I'm just a site mail away!
HugZ!
Ariana
Oh and BTW, I meant set the Preview size in image 1.... duh! LOL!!!
toastie ( ) posted Tue, 07 August 2012 at 11:35 AM
Thanks - I'll give that a go next time and see if it works for me too.
FutureFantasyDesign ( ) posted Tue, 07 August 2012 at 11:49 AM
:D
