Sun, Feb 16, 9:09 PM CST
Subject: Question about lighting in poser.
makis12 ( ) posted Tue, 07 August 2012 at 12:53 PM · edited Sat, 15 February 2025 at 4:13 AM
I made a scene in poser  and i want to do the following.I want the lights to remain stable no matter if i move the camera.How can i do that?The thing is that i did it once and i forgot.Can you help?Thanks
Hana-Hanabi ( ) posted Tue, 07 August 2012 at 1:05 PM
Stable? As in, you want the lighting angle to match the camera angle? Have you parented your lights to your camera?
花 | 美 | 花美 | 花火
...It's a pun.
makis12 ( ) posted Tue, 07 August 2012 at 1:12 PM
No.That s the thing.I don t do that and when i rotate the camera the lights are rotated also.
Hana-Hanabi ( ) posted Tue, 07 August 2012 at 1:14 PM
Huh. Check in your heirarchy editor to make sure the lights aren't parented to anything?
花 | 美 | 花美 | 花火
...It's a pun.
makis12 ( ) posted Tue, 07 August 2012 at 1:23 PM
If i want to parent a light to the camera what should i choose?Click on the  light ---->object---->change parent---->main camera?I m asking because when i click on a light and go to  object menu change parent option is deactivated.
Thanks
Hana-Hanabi ( ) posted Tue, 07 August 2012 at 1:31 PM
What kind of light is it? I'm not sure it works with Infinite lights, but you should be able to parent Spots or Points, I'm fairly certain.
花 | 美 | 花美 | 花火
...It's a pun.
hborre ( ) posted Tue, 07 August 2012 at 1:32 PM
You cannot parent infinite lights, only spot and point.  If you want to parent the infinite, first change it into a spot or point, parent, then change it back to an infinite.
makis12 ( ) posted Tue, 07 August 2012 at 1:45 PM
A ha.I got it.This option (change parent) works only with spot lights.And you know what?When i set every light as a spot light and parent it to the main camera i achieve what i want.
hborre ( ) posted Tue, 07 August 2012 at 2:19 PM · edited Tue, 07 August 2012 at 2:19 PM
However, light setups in a scene are stationary, they will not move relative to the stage if you change your camera position.  It sounds to me like you just want a guide light attached to your camera and move whenever you change camera position and angle.  Not very realistic in terms of natural lighting, unidirectional.  Now, your best alternative would be to set up your lighting according to your scene, attach a 'spot' light to your camera but change the diffuse and specular chips in the MAT Room to black.  With this arrangement, you can light your preview and render without adding any additional light to the scene.
Edit:  Glad to see that works for you.
cspear ( ) posted Wed, 08 August 2012 at 2:40 AM
To parent an infinite light:
  1. change it to a Spot
  2. parent it to whatever
  3. change it back to infinite
PoserPro 11 - Units: Metres
Adobe CC 2017
monkeycloud ( ) posted Wed, 08 August 2012 at 4:18 AM
Interesting to know about that workaround for parenting an infinite light - many thanks
cspear ( ) posted Wed, 08 August 2012 at 7:01 AM
I discovered recently that if you have Dimension3D's 'XO' (eXtended Object Manager) script - available in the marketplace - it will parent infinite lights without any messing about.
Adobe CC 2017
