Sat, Jan 25, 5:45 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
Subject: Poser Pro 2012 - Problem wth render problem
Philywebrider ( ) posted Fri, 10 August 2012 at 3:40 AM · edited Sat, 11 January 2025 at 9:52 AM
Poser Pro 2012  - Problem wth render problem. In poser 8 when I rendered and exported an PNG image without a problem. When I render and export an PNG image with Poser Pro 2012 it exports the ground along with the image/figure, as in the sample image. Is there anyway I can rid /stop the ground from export/printing?
vilters ( ) posted Fri, 10 August 2012 at 4:39 AM
Toggle the ground plane OFF before rendering?
Ctrl+G (from memory)
shvrdavid ( ) posted Fri, 10 August 2012 at 5:28 AM
The default scene in Poser Pro 2012 is set differently than previous versions, that is why you see the floor.
You can change the default scene options to be the same as previous versions.
moriador ( ) posted Fri, 10 August 2012 at 5:45 AM · edited Fri, 10 August 2012 at 5:45 AM
If you don't want the ground at all, make it invisible, as suggested above.
If you want only the shadows from the ground to appear in your PNG, then:
Go into the advanced materials tab.
Select the ground prop.
Check Shadow_Catch_Only.
(I think in previous versions of Poser this was the default for the ground.)
hborre ( ) posted Fri, 10 August 2012 at 9:56 AM
Online Now!
Making the ground invisible can be found in the Properties/Parameters panel.
Philywebrider ( ) posted Fri, 10 August 2012 at 11:24 AM
Problem solved! Thank you everyone, I really appreicate your help. Thanks again.
