PP2012 materials have shadow catch built in. Turn it on for the ground.
It's on the PoserSurface node in the advanced material room. It's called Shadow_Catch_Only.
I was already a beginner with the Poser 6. With the Poser Pro 2012 I'm not understanding almost anything.
I should not have explained properly, (sorry my bad english).
I'm trying to render a Character (V4 and her shadow), over imported background picture, like the image attached, (which were created in Poser 6).
Now, using the Poser Pro 2012, I'm not able to do the same as I did in Poser 6. One of the problems is that after so long, I can't remember more as I did in Poser 6.
In these image I did not use photoshop. And in all other images that are in my gallery the shadows of Characters were designed over imported background picture, using only Poser 6.
Once again thank you very much for your attention and patience with this old beginner.
My answer is the same.
Please explain what you did not understand. I know what you're trying to do.
The solution is as I said.
Quote - PP2012 materials have shadow catch built in. Turn it on for the ground.
I forgot to post before but the bagginsbill instruction worked perfectly.
It is very simple to make and really works.
Thank You Bill
Dear friends,
I'm with render problems.
I can't render the shadow over imported backgroud picture.
When I try to render the ground shows up too.
In poser 6 I could do it properly, but does so long that don't use Poser 6 which I forgot how to do it.
I am now using the Poser Pro 2012.
Can someone help me???
