Tue, Dec 24, 12:19 PM CST
Subject: Saving combined figures to library.
BobW ( ) posted Tue, 16 November 1999 at 11:47 AM ยท edited Wed, 27 November 2024 at 1:52 PM
Is there a way to save two figures as one to the figure library? This is what I do Add P4 nude man to document window Add mens shorts from the male clothing menu Conform the shorts to P4 nude man Set the parent of the shorts to the P4 figure (I have also tried parenting the shorts to other things in the hierarchy editor) Try to save in a figure directory and only get one figure. Hoping you can help
viper ( ) posted Tue, 16 November 1999 at 12:09 PM
what i do is save my charater with clothing as a .cr2 file in the library. then save the scence as a .pz3 file and then rename the pz3 file to the same a the cr2 and then i can open it in poser from the menu. i works most of the time Im hopeing mason will have a tutorial soon
JeffH ( ) posted Tue, 16 November 1999 at 12:10 PM
You can only save one figure per CR2, but there is a way around this. Save your file as a pz3, then manually rename it to .CR2 and put it in your library directory overwriting the CR2 you made in your first attempt. -JH.
JeffH ( ) posted Tue, 16 November 1999 at 12:28 PM
Viper, Integrating the P4 clothing into a figure is easy. Using this figure and clothing as an example: Open the P4nudemale OBJ in Compose, then Open the shorts OBJ merging it with the file already open. Save the OBJ file to a new name in the same directory as the nude figure. Open the p4 nude male CR2 in an editor such as CR2editor and change the two directory references to point to your new OBJ file. Open this new edited CR2 inside Poser, let the resource build and there you have it...the nude male wearing the shorts. -JH.
BobW ( ) posted Tue, 16 November 1999 at 12:53 PM
Thank you all so much!
BAM ( ) posted Tue, 16 November 1999 at 12:53 PM
Here's another way. You can save (normal save)the figure with clothes and in posed position in a .pz3. Then import the .pz3 using the import function. In this way you can save various figures and poses in separate files and then import them all in when you want to compose the whole scene.
BAM ( ) posted Tue, 16 November 1999 at 12:55 PM
Does your method ultimately save resources (saved file size or internal memory) or make things work quicker?
JeffH ( ) posted Tue, 16 November 1999 at 1:06 PM
There's a CR2 utility I've heard of on the Poser list that can strip the camera and lights info out of a pz3 file, so that might save some memory. http://users.neca.com/dwilmes/cr2edit.html This is different from the one you'll find on the FS pages. -JH.
JeffH ( ) posted Tue, 16 November 1999 at 2:04 PM
Oops, I just remembered something about integrating the clothing into the male nude figure. It's a bit more complictated than using the female nude because of the no-gen switch in the cr2. Luckily JKeller worked up a figure for this purpose that has no genital switches in the cr2. You can find it at the PropsGuild site. -JH.
