Viper, Integrating the P4 clothing into a figure is easy. Using this figure and clothing as an example: Open the P4nudemale OBJ in Compose, then Open the shorts OBJ merging it with the file already open. Save the OBJ file to a new name in the same directory as the nude figure. Open the p4 nude male CR2 in an editor such as CR2editor and change the two directory references to point to your new OBJ file. Open this new edited CR2 inside Poser, let the resource build and there you have it...the nude male wearing the shorts. -JH.
Oops, I just remembered something about integrating the clothing into the male nude figure. It's a bit more complictated than using the female nude because of the no-gen switch in the cr2. Luckily JKeller worked up a figure for this purpose that has no genital switches in the cr2. You can find it at the PropsGuild site. -JH.
Is there a way to save two figures as one to the figure library? This is what I do Add P4 nude man to document window Add mens shorts from the male clothing menu Conform the shorts to P4 nude man Set the parent of the shorts to the P4 figure (I have also tried parenting the shorts to other things in the hierarchy editor) Try to save in a figure directory and only get one figure. Hoping you can help
