Tue, Jan 14, 7:40 PM CST
Subject: Advice on printing Vue renders
Clouseau ( ) posted Tue, 14 August 2012 at 10:19 AM · edited Tue, 14 January 2025 at 9:45 AM
Clouseau is wanting to print and frame some Vue renders. Does anyone have any useful tips and advice on this. Clouseau uses Vue 8 and has photoshop. He is wanting to print an image up to 1 meter long.
Any advice is welcome.
silverblade33 ( ) posted Tue, 14 August 2012 at 4:18 PM
1 metre?
well you'll need ot enlarge it up to
300 pixels per 25 mm of print size
so 1000mm/25 =40
40x300=12000
ie, largest dimension of image needs ot be enlarged up to approximately 12000 pixels for a good print.
You MAY get away with 100 pixels per 25mm, so 3000 pixels on largest dimension.
photoshop is ok, but Fractal resizer is better
http://www.ononesoftware.com/products/perfect-resize/
For such large prints, it's vital to render the final image in Vue at LEAST 1600 pixels in size (largest dimension)
ShawnDriscoll ( ) posted Wed, 15 August 2012 at 1:13 AM · edited Wed, 15 August 2012 at 1:18 AM
D-size paper (34" x 22") at 200 dpi.
Your render would be 6800 x 4400.
Try that first before deciding on 300 or 600 dpi which need larger size renders.
A1-size paper (841mm x 594mm) would be an equivalent.
Paula Sanders ( ) posted Wed, 15 August 2012 at 8:53 AM
In Photoshop use a program like onOne Resize 7 or Alien Skin Blowup. They enlarge fractally. I work 2200 x 14xx depending on my format. I blow it up to 13" x 19". I have also worked smaller when an image is taking a lot of time to render. I print at 240 on my Epson printer.
