Wed, Jan 8, 2:58 AM CST
Subject: Dream Home Zero Poses
ypvs ( ) posted Fri, 17 August 2012 at 6:05 PM · edited Wed, 08 January 2025 at 2:57 AM
file_485299.txt
Seen a couple of old threads for people neeeding these. Created a new thread to bring it to the top.
Dream Home Zero poses- will need to go into your runtime/pose folder. File has been renamed to get it into the forum, you will need to remove the .txt extension to change it back to a zip file.
Not sure if the poses go into DAZ Studio but if you open the PZ2 file with WordPad you can get the XYZ Tran and Rotate details for the room body.
Once zeroed the room can be parented to an invisble dummy prop and the prop rotated/moved
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Windows 7 64 bit, Avast AV, Comodo Firewall
Intel Q9550 Quad Core cpu,  16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
Lower Floor Plan
ypvs ( ) posted Fri, 17 August 2012 at 6:06 PM
Upper Floor Plan
GeneralNutt ( ) posted Fri, 17 August 2012 at 6:27 PM
Thank You very much.
cedarwolf ( ) posted Fri, 17 August 2012 at 6:40 PM
Holy Cow!  I was just about to write this off as a bad purchase.  Thanks so very, very much.  I'll try to figure out the instructions and follow them.  I just tried to convert the file back to a zip file but I apparently don't know enough about Windows 7 to make it work.  It still opens up as a text file.  Suggestions?
ssgbryan ( ) posted Fri, 17 August 2012 at 6:50 PM
Quote - Holy Cow!  I was just about to write this off as a bad purchase.  Thanks so very, very much.  I'll try to figure out the instructions and follow them.  I just tried to convert the file back to a zip file but I apparently don't know enough about Windows 7 to make it work.  It still opens up as a text file.  Suggestions?
Save it without the .txt ending should get it going.
cedarwolf ( ) posted Fri, 17 August 2012 at 7:16 PM
Thanks ssgbryan, didn't work.  For some reason I don't get a "save as" option, only "save" or "open in notepad."  I tried saving it from notepad as a .zip but that didn't work either.
GeneralNutt ( ) posted Fri, 17 August 2012 at 7:17 PM
Just right click on the saved file and rename, without the .txt if your using windows.
ypvs ( ) posted Sat, 18 August 2012 at 3:30 AM
file_485317.txt
Cedarwolf, click on link and Save, when you get the Save As screen you need to change the filename so that it ends in .zip NOT .txt
Just modified the Zip file so it conatins the runtime structure so you only need drop it into your poser directory
Working on a higher res Floor Plan now I've got a Widescreen monitor and adding the room names
ypvs ( ) posted Sat, 18 August 2012 at 4:28 AM
Updated Ground Floor Plan
ypvs ( ) posted Sat, 18 August 2012 at 4:29 AM
Updated Upper Floor Plan
Basement (!)
cedarwolf ( ) posted Sat, 18 August 2012 at 9:56 AM
ypvs, you are truly generous and patient.  I guess my Win7 is broke somehow.  It refuses to let me actually rename the .txt as a .zip and have it work that way.  When I download the file I get this pop up.  I'll keep trying.  I may have to switch computers.  LOVE the archetctural maps...those are incredibly handy.  Again, my thanks.
GeneralNutt ( ) posted Sat, 18 August 2012 at 10:04 AM
Does firefox ask you were to save the file next? You can make your change after saying ok. If you have firefox set to auto save somewhere, then you could right click on the completed download from the firefox downloads screen and choose open containing folder. From there right click on the file and rename. Does that help?
ypvs ( ) posted Sat, 18 August 2012 at 10:15 AM
Try this link about changing file extensions in Win7- just need to remove the .txt to leave it .zip
http://www.mediacollege.com/microsoft/windows/extension-change.html
GeneralNutt ( ) posted Sat, 18 August 2012 at 10:54 AM
I forgot about the windows hiding extentions thing, been killing that on new installs since well long time ago.
cedarwolf ( ) posted Sat, 18 August 2012 at 10:57 AM
I did not know this option even existed, ypvs!  That took care of the situation.  Now...onward!
ypvs ( ) posted Sun, 19 August 2012 at 4:02 AM
Updated Updated Ground Floor Plan!! with missing Lanai and Entrance
