Holy Cow! I was just about to write this off as a bad purchase. Thanks so very, very much. I'll try to figure out the instructions and follow them. I just tried to convert the file back to a zip file but I apparently don't know enough about Windows 7 to make it work. It still opens up as a text file. Suggestions?
Quote - Holy Cow! I was just about to write this off as a bad purchase. Thanks so very, very much. I'll try to figure out the instructions and follow them. I just tried to convert the file back to a zip file but I apparently don't know enough about Windows 7 to make it work. It still opens up as a text file. Suggestions?
Save it without the .txt ending should get it going.
Just modified the Zip file so it conatins the runtime structure so you only need drop it into your poser directory
Working on a higher res Floor Plan now I've got a Widescreen monitor and adding the room names
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Windows 7 64 bit, Avast AV, Comodo Firewall
Intel Q9550 Quad Core cpu, 16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
Does firefox ask you were to save the file next? You can make your change after saying ok. If you have firefox set to auto save somewhere, then you could right click on the completed download from the firefox downloads screen and choose open containing folder. From there right click on the file and rename. Does that help?
Try this link about changing file extensions in Win7- just need to remove the .txt to leave it .zip
http://www.mediacollege.com/microsoft/windows/extension-change.html
Dream Home Zero poses- will need to go into your runtime/pose folder. File has been renamed to get it into the forum, you will need to remove the .txt extension to change it back to a zip file.
Not sure if the poses go into DAZ Studio but if you open the PZ2 file with WordPad you can get the XYZ Tran and Rotate details for the room body.
Once zeroed the room can be parented to an invisble dummy prop and the prop rotated/moved
