Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 03 10:43 am)
i have tried everything on the simulation settings from being silk to leather, and reducing and increasing air damping, is there a way to tell the square to be effected by the wind force? as the square just dangles in the air after a simulation...
Getting old and still making "art" without soiling myself, now that's success.
thankyou laddona i shall give this a try. i have no idea why smith micro have not made the windforce more friendly, so far it is the only thing ive used in poser that has never in 10 years given me any results at all.....time for an update,lol
Believe me or not, I suffer with the Winforce tool for years, till desiderius my partner give me a smal hint what i did wrong all the years.
Maybe you have luck too.
If you have still problems, you can pm me anytime, maybe we find out what go wrong there :)
― Marcus Aurelius,
Quote - DAMN.. it works with ease in poser 8 but will not under any cicumstances run in poser 2012 sr3...... Looks like i found a bug.....
cant believe how easy it was in P8
:) Great, and now I go to mantis and write a bug report .
I will give it a try too as soon my Poser is finish to render but when you say in P8 it works in P2012 not, than I guess it is a bug.
― Marcus Aurelius,
I think you found a bug. The image above was before sr3 and the one below is the same pz3 file calculaed with sr3. Click to enlarge.
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
I have tried everything to get the windforce to work on a square cloth and nothing, i have used all of the techniques used in these forums, so where am i going wrong or if someone can give it a try is this a fault with Poser 2012 sr3?
I have put a hi res square choreographed by the top edge in the scene then whilst selected added a windforce, set the winforce amplitude to values from 1 to 500 and range from 2 to 10000 and spread angle from 26 to 90 degrees, and the square is positioned from close to the wind source to mid and distant inside the force cone.... im getting fed up with this now so can someone please help... oh and before someone says read the manual, i have and i would do better to contact the dead for an answer... its rubbish
