Wed, Jan 29, 6:32 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 5:52 pm)
Subject: Morph Tool Question
3doutlaw ( ) posted Tue, 28 August 2012 at 2:52 PM · edited Tue, 28 January 2025 at 5:49 AM
Ever use the morph tool to eliminate some poke through on an item (say around the torso of V4 on a shirt), and when you click to "pull" a little bit, it switches from the shirt-abdomen to V4-abdomen, and then does nothing?!?
Any way to avoid that nuisance?
vilters ( ) posted Tue, 28 August 2012 at 3:02 PM
Hold the shift key down when selecting the clothing.
Santel ( ) posted Tue, 28 August 2012 at 4:34 PM
which is still not a perfect solution as you can still loose focus...which creates a suggestion for the next morph tool update; the ability to not only select a certain part of a figure (now possible) but also a lock of somekind so only the object currently selected whether it be a figure or a prop will be morphed and not the 'focus' jumping game currently available. I'd be more than happy to be required to make an extra mouse click on some control of some kind to prevent the tedious re-focusing usually required :)
3doutlaw ( ) posted Tue, 28 August 2012 at 4:42 PM
Shift key seems to work, thanks Vilters!!
600405 ( ) posted Tue, 28 August 2012 at 4:51 PM
yes, that's an overdue function, and i'm surprised, it still is an issue.
if nothing else helps, you can hide the disruptive mesh parts temporarily in the parameters tab, but that makes the morphing kind of a guessing game and you'll have to work very carefully.
motox ( ) posted Tue, 28 August 2012 at 5:46 PM
It's best when removing poke thru to push the underlyng figure in not pull the cloths out.
Snarlygribbly ( ) posted Tue, 28 August 2012 at 6:38 PM
Ok .. I just made a little addon to help with this :-)
It's only for Poser 9 / PP2012 with SR3
If you click on 'Stick' then the addon makes a note of the currently selected actor and then won't let Poser change the selection to anything else.
Click on 'Unstick' to go back to normal operation where you can select other actors.
Maybe useful for stuff other than just the morph tool?
Free stuff @ https://poser.cobrablade.net/
hborre ( ) posted Tue, 28 August 2012 at 6:45 PM
Online Now!
Bravo, Snarly does it again!!!!
Snarlygribbly ( ) posted Tue, 28 August 2012 at 6:55 PM
Grab it from here if you have Poser 9 or Pp2012 SR3:
http://snarlygribbly.org/3d/downloads/focuser.zip
I only threw it together a few moments ago, so play carefully with it :-)
toastie ( ) posted Tue, 28 August 2012 at 7:28 PM
Hoorah! Thanks for this. That's something that's been getting really annoying with the morphing tool!
3doutlaw ( ) posted Wed, 29 August 2012 at 7:42 AM
Quote - It's best when removing poke thru to push the underlyng figure in not pull the cloths out.
Well...thats a good point!  I really had not thought of it that way.  In this particular case, I had a piece of jewelry under clothes sticking through, so a little bump on the clothes made more sense.
BTW, thanks for the utility, SG!
monkeycloud ( ) posted Wed, 29 August 2012 at 8:11 AM
Cool - thanks Snarly! 👍
Janl ( ) posted Wed, 29 August 2012 at 8:22 AM · edited Wed, 29 August 2012 at 8:22 AM
I've installed this script and it has installed to the python -> addons directory but how do I run scripts from the addon directory? Are they run from the python scripts palette?
Janl ( ) posted Wed, 29 August 2012 at 8:28 AM
Oh, all of a sudden the Windows -> Addons option has appeared!
Thank you for a very useful script, Snarly!
Janl ( ) posted Wed, 29 August 2012 at 8:42 AM
Oh, all I'm getting now is this window which is not what Snarly shows above. :sad:
monkeycloud ( ) posted Wed, 29 August 2012 at 8:47 AM
That looks like just great life advice apart from anything else 😉
Janl ( ) posted Wed, 29 August 2012 at 9:03 AM
Quote - That looks like just great life advice apart from anything else 😉
:lol: Maybe that is what was because, after restarting Poser Pro 2012, my addons link has disappeared now. :lol:
fonpaolo ( ) posted Wed, 29 August 2012 at 11:00 AM
Snarlygribbly, you're a genius! :thumbupboth:
Snarlygribbly ( ) posted Wed, 29 August 2012 at 12:02 PM
Quote - > Quote - That looks like just great life advice apart from anything else 😉
How's it going now? Have you managed to get it working?
I'll try to help you get it working if you can provide me with enough information ...
moriador ( ) posted Wed, 29 August 2012 at 1:23 PM
Snarly, that's wonderful!
Do you think you can manage a quick script to get Poser Pro 2012 to brew some coffee and toast a scone while it's rendering? If anyone can do it...
Janl ( ) posted Wed, 29 August 2012 at 2:12 PM · edited Wed, 29 August 2012 at 2:18 PM
> Quote - > Quote - > Quote - That looks like just great life advice apart from anything else 😉 > > > >   > > > > :lol: Maybe that is what was because, after restarting Poser Pro 2012, my addons link has disappeared now. :lol: > > How's it going now? Have you managed to get it working? > > I'll try to help you get it working if you can provide me with enough information ...
Thank you for your offer of help, Snarly. I don't seem to have the Windows -> addon option. I must have done something when playing with the new script and it appeared but now it has gone again so I can't run this script or the subdivision one. :sad:
ETA: This is all I have under Window.
Snarlygribbly ( ) posted Wed, 29 August 2012 at 2:56 PM
This probably means that the addons folder is missing.
I just tested this by renaming my addons folder to addonsx and the Window/Addons menu disappeared for me too.
The addons folder will be here:
For me, this is:
C:Program FilesSmith MicroPoser Pro 2012RuntimePythonaddons
Cheers,
Snarly
Janl ( ) posted Wed, 29 August 2012 at 3:00 PM · edited Wed, 29 August 2012 at 3:01 PM
I have the addons folder at:
C:Poser Pro 2012RuntimePythonaddons
In that folder I have:
poseraddon.py
poseraddon.pyc
and the PythonShell folder.
I did have your two scripts at one point but then I removed them and put them in their own runtime to see if that made any difference.
Snarlygribbly ( ) posted Wed, 29 August 2012 at 3:32 PM · edited Wed, 29 August 2012 at 3:35 PM
Hmm... baffling!
I don't know why it isn't showing for you then :-(
You could do a quick test: add my scripts to their own runtime and make sure that the runtime is linked to.
Now open Poser.
If you get a message that 'poseraddon' is missing, then it means Poser found my addon scripts but that the main addons folder ('C:Poser Pro 2012RuntimePythonaddons') can't be found.
If you get no error messages it means Poser can't find any addon folders at all (unless, of course, everything is working fine and all the addons are showing!) and, assuming you have set them up correctly, perhaps there is something wrong with your Poser installation?
Most puzzling! :-(
Edited to add: It might be worth checking that you are in fact still on SR3! Rolling back to SR2 would cause the menu to disappear ...
Janl ( ) posted Wed, 29 August 2012 at 3:52 PM
I'm not getting any error message, Snarly and I'm on SR3. I've never done a roll back. I'm thinking maybe it is because I didn't install to the Program Files directory. I know I have seen the addon link at some point in the past so maybe a SR has removed it or perhaps somehow I've messed up my installation. I don't have any other problems so I'm not sure. :unsure: It seems that maybe I should reinstall at some point just to rule out the latter. Thanks for your help anyway.
Santel ( ) posted Wed, 29 August 2012 at 4:37 PM
Thanks for this....just great!!!!!
pokeydots ( ) posted Wed, 29 August 2012 at 4:57 PM
Thanks!
Poser 9 SR3  and 8 sr3
Processor Type:  AMD Phenom II 830 Quad-Core
Hard Drive Size:  1TB
Processor - Clock Speed:  2.8 GHz
Operating System:  Windows 7 Home Premium 64-bit
Graphics Type:  ATI Radeon HD 4200
System Ram:  8GB
shedofjoy ( ) posted Wed, 29 August 2012 at 6:44 PM
Fantastic snarly, this is awesome,thankyou
Getting old and still making "art" without soiling myself, now that's success.
moriador ( ) posted Thu, 30 August 2012 at 2:34 AM · edited Thu, 30 August 2012 at 2:34 AM
Already finding this extremely useful. Works beautifully.
I didn't realize that the "focus", unless unstickied, does extend into the material room, which made me wonder what was going on momentarily, as my selection kept returning to the same thing. I'm not sure what utility that might have -- I guess if you're changing/testing a bunch of materials on a figure that's in the background and keep selecting the wrong things (happens to me a lot when I'm testing skydomes), it could be useful to sticky it. But it's by no means a problem. Wondering what other uses it might have... Nifty little script. Thank you for making it.
Janl ( ) posted Thu, 30 August 2012 at 12:30 PM · edited Thu, 30 August 2012 at 12:39 PM
It looks like my problem with the missing addons under window was due to Netherwork's Scripts Auto Launch. The script has been updated so if you are suffering the same problem then redownload the script and ...
Quote - If you are experiencing an issue where the add-ons are not showing up under "Window" in Poser's menu, load Scripts Auto Launch and press "Restore Poser" then immediately press "Launch with Poser". That should fix any funky behavior.
It's just my luck that I didn't get notification about this before I reinstalled Poser. :lol:
The script is working fine now, Snarly. Thank you. 😄
EClark1894 ( ) posted Thu, 30 August 2012 at 12:54 PM
You know, I don't use the morphing tool much for that very reason.
Great idea, Snarly.
vholf ( ) posted Fri, 31 August 2012 at 8:57 PM
Snarly! You rock!, what a great idea.
Is the script source included? I'd love to take a look and see how the new plugin system works, I'm trying to script something myself.
Just for the sake of getting an idea out there, which complements your great tool, is a "freeze" script, most CG tools I've used have this, which just freezes the selected object and makes it unselectable (some even change the display when doing that).
You would select a figure or body part and hit freeze. Then you could unfreeze figures from a select list.
Santel ( ) posted Sat, 01 September 2012 at 11:25 AM
not to be repetitive but thanks again for this as well as the snow machine and ezSkin :)
Snarlygribbly ( ) posted Sun, 02 September 2012 at 5:53 AM
file_485986.txt
> Quote - Is the script source included? I'd love to take a look and see how the new plugin system works, I'm trying to script something myself.
Sure. Attached.
Remove the '.txt' extension when you save it - the file is a zip archive.
There is no licence file: the code is so minimal that it might as well be considered public domain.
vholf ( ) posted Sun, 02 September 2012 at 1:41 PM
Thanks!, but you attached the binary again :P
Snarlygribbly ( ) posted Sun, 02 September 2012 at 8:52 PM
Quote - Thanks!, but you attached the binary again :P
No, the zip contains the source code. I just checked.
vholf ( ) posted Sun, 02 September 2012 at 10:28 PM
Oh, sorry! it was a bad download, for some reason it got truncated. Thanks again :D
Snarlygribbly ( ) posted Mon, 03 September 2012 at 8:30 AM
I'd be interested to see how your idea progresses too.
Feel free to exchange ideas / code snippets etc. if you think I can be of any help.
