Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 7:53 am)
She looks a little like Kelly Bensimon. ย I think she is fantastic. ย Looks very original. ย I like her eyes, and her cheeks. ย The only small critique I could give is that her lipstick doesn't cover all the way to the bottom of her lip in the OP. ย I don't know if this is something you have fixed since then so if so just ignore. ย Usually lipstick extends even a little bit off the lips IRL but never ends before the lip ends.
I am: ย aka Velocity3dย
Very good work, a strong identity in the face. I like the large eyes and strong cheekbones, and the face that looks "lived-in". Can we see her smiling?
Poser 11 Pro, Windows 10
personally, I would go for less symmetry, and less perfection in the textures. In the eyes, I think the pupils are a bit too large. Identical eye-reflections reveal the artificial nature of the character, so you might elaborate on that a bit as well. Devil is in the details, as usual.
promo looks pretty good, though, worth the effort. Looking forward to more.
- - - - -ย
visitย www.aRtBeeWeb.nl (works) or Missing Manuals (tutorialsย & reviews) - both need an update though
I would use another hair prop for your promos. Even better, a hat or some such head prop so the hair does not detract from your work. How about a nice Zbrush scalp displacement with a morph to simulate hair as an option? Also, I'd add in a low level Ray Trace light to clear up the shadow mess around the eyelashes and hair caused (I'm guessing) by emitter props. She comes across as heavily mascaraed and perhaps not your intention. Iris reflections bug me. I'll assume it's the emitters again. I use dedicated emitters (60% spheres 2-5 ambient, non emitting, no shadow) set next to cam for eye specular. Then panels set off camera for light...
Also,,, if you are offering a FBM, you might as well have your own joint fixes that work correctly for the body shape. Good selling point.
From what I can see, I think the figure looks very nice in practically every aspect. The only thing that I thought detracted was the eyebrows. They seemed to be flat - someone mentioned this earlier. Maybe adding some type of bump map would help there.
I'm not sure if you would want to consider using the eyebrow portion of the figure added in V4.1 and later IIRC, instead of placing it directly on the face map, since that would allow for easier change to the eyebrow color.
I think that, on the same note, and if it even applies, it would be good for the drapes to be able to match the carpet....
That's just my 2 cents.
I'm working on getting her finished up as we speak. I have some more joint morph fixers to do (doesnt take long) (promo renders to do) and the packaging, I have Dr Phils programs for creating cr2's and this is my third product Ive put up for sale, so Ive done it before. I tend to be rather slow but I'm hoping in a week or so. Hopefully 2 weeks at the most. All my jpg maps are finished and in their correct location, all shader/materials are done and in their correct file structure, so almost all the work is done.
Thanks for you interest!
Yes, I have had mixed results with turning on light emitter for skin. It tends to cause areas to "glow" and I just havent generally been very happy with the results, (although in the above case it worked ok) I also dont like "gamma correction" I think it washes out the skin color and details. I like the darker shadows, I guess I tend to like the more "dramatic look"
To my eye the darker shadows help define form and texture, but of course as individuals we all have our preferences
Gamma correction, in a way, is a contrast dial. If you want more contrast, it's perfectly correct to set the value to something lower than 2.2.
Your very welcome, thank you for your kind comments!
I use "inflate balloon" rather than "inflate" because it runs a micro polish sequence after each inflation. I do them in very small increments like .03 at a time to just bring the texture up to the level where I want it. The micro polish seems to help keep things from getting too ragged and helps to produce a more natural texture
