Not in the current or prior versions. Load a primative plane, scale it (x,y) to match picture size (i.e. 640x400 would be 64% x40%) and then do scale to match your requirements. Load the picture onto the plane in the material room
Bill
Put the image on a one-sided square. Scale the square to the aspect ratio and size you want. Then you have a real 3D prop, painted, as is done in real life. You can then zoom in on it, scale it up and down, move it around, etc.
What I do is load a square primitive, size the aspect ratio to match the background image, and put the background image on the square materials, and turn off texture filtering. Then I can move it around wherever I want.
I'm rendering at the moment, so I can't check but I believe that in the material room, when you click on the image map, at the bottom of that panel you have the option for texture filtering: quality, crisp, off, etc.
"Hi Res" in the 'Square Hi-Res' refers to the polygon density, which as far as I know should have no effect on image maps used on it. However the UV map on the Poser 'one sided square' (post P6 or 7) is wrong (the image overlaps the square).
A background image is not affected by the scene lighting, but by default a Poser prop is. You can make the image independent of the lighting as follows. In the Advanced tab of Material Room, use these settings:
Defuse_Color = white
Defuse_Value = 0
Specular_Color = Black
Specular_Value = 0
Ambient_Color = white
Ambient_Value = 1
Create an Image_Map node and plug it into both the Ambient_Color and Defuse_Color. Set the Filtering to 'Crisp'. Load your graphic into the node. You should also turn off 'Casts shadows' in the prop's Properties tab.
Another thing you can do is to parent the square to the Main Camera (for example), so that the square will move with the camera, then you don't need to adjust it every time you move the camera.
Attached above is the text of a square prop that has been set up as above, and is smart-proped to the Main Camera. You will need to remove the ".TXT" part of the file extension and place it in a props folder, before you can use it in Poser.
To use; load it in poser, load an image into its Image_Map node. If necessary zTran it until it is behind all the elements of your scene. Adjust the scale of the prop until it just fills the view-port.
Okay pp2012 sr3
I did look through the manual for instances of 'Background'
I did search through the forum for similar questions.
Is there no way to zoom into the background in this version of Poser? It seems like it just loads in one place and there is only moving the scene around at that point. What if I want to render just one part of the background and I want it to be a large portion of the render? I can't figure out how to manipulate this thing at all. Don't see anything in the context menu for it that seems to do anything either.
Help porfavor.
I am: aka Velocity3d
