Sat, Feb 15, 4:07 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Subject: Poser 9 Downloads folder.
Jacobus01 ( ) posted Thu, 06 September 2012 at 12:55 PM · edited Sat, 15 February 2025 at 3:49 AM
Hi all,
Today I received my Poser 9, I installed it on my win7/64bit PC, using the default installation setting, which makes the 'downloads' folder in C:UsersPublicDocumentsPoser 9 Content
After installing the folder is there, but when I unzip some content to it, Poser doesn't read the folder, it stays 'empty' in Poser, while the content is in the folder...
Some help would be appreciated..
hborre ( ) posted Thu, 06 September 2012 at 12:56 PM
Did you install content while Poser was open?  If so, just refresh the library at the right side of the folder icons.
LaurieA ( ) posted Thu, 06 September 2012 at 12:57 PM
If you have Poser open when you install, you'll need to refresh the folder (small circle with arrow if you hover over the folder with the cursor). It doesn't show automatically. It will show if you exit and then re-enter Poser.
Jacobus01 ( ) posted Thu, 06 September 2012 at 1:14 PM · edited Thu, 06 September 2012 at 1:16 PM
I tried the refresh button, nothing shows up... even after restarting Poser... nothing
FrankT ( ) posted Thu, 06 September 2012 at 1:25 PM
Quote - using the default installation setting
is your problem.  It has placed your runtime in a folder which Poser can't write to.  There are a number of threads on this in the Poser forums.
My Freebies
Buy stuff on RedBubble
hborre ( ) posted Thu, 06 September 2012 at 1:38 PM
Rereading the original post, a Poser 9 content folder is correctly created where it is suppose to be for the default installation.  However, a Downloads folder is not created.  Your content is being placed into the original Poser folder within Program Files.  You will need to move your content to another location.  I just checked my PP2012 install using default settings and a Downloads folder does not coexist with the content folder.
Teyon ( ) posted Thu, 06 September 2012 at 2:39 PM
If you unzip via the Content Tab in Poser, it usually places content within the Downloads folder. Or it used to anyway. I haven't bought content in years so that may have changed.
nobodyinparticular ( ) posted Thu, 06 September 2012 at 2:55 PM
Quote - If you unzip via the Content Tab in Poser, it usually places content within the Downloads folder. Or it used to anyway. I haven't bought content in years so that may have changed.
Gives you the option of the Download folder, or you can sarch for a folder, similar to the add library tab.
hborre ( ) posted Thu, 06 September 2012 at 3:08 PM
However, under this particular circumstance, Poser 9 is not seeing content loaded into the Downloads folder because that it is in a restricted area and Win7 UAC is interfering.
Jacobus01 ( ) posted Thu, 06 September 2012 at 4:17 PM
It seems to work now... just the way I installed it... strange.
Must have overlooked something in my hurry to start with the program, or some strange X-files mystery must have happened..
Tnx anyway;)
moriador ( ) posted Thu, 06 September 2012 at 8:16 PM · edited Thu, 06 September 2012 at 8:24 PM
I just tested it.
It unzips to wherever you tell it to - by default: users/public/documents/Poser xxxx content/downloads.
Then it creates and links a runtime called "downloads" where you'll find the content. However, you need to refresh that runtime/library to see newly installed stuff.
It works. It works whether or not Poser is installed in Program Files because it doesn't install content into Program Files unless you tell it to.
It might not work if you point the installer to a runtime within Program Files, but that is not the default nor the recommended location for content.
