Wed, Nov 13, 10:06 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: poseray
darquevision ( ) posted Fri, 07 September 2012 at 3:53 AM · edited Tue, 12 November 2024 at 5:06 PM
i am wondering how export a certian "group" in poseray. i have come across a lightwave file that contains several items which are grouped per item. i can view them seperately but cant export each group indiviually. is there a way?
i am extremely new to poseray and have basically used it once to export some vehicles which textures got lost in a direct import to poser.
thank you in advance
CyberDream ( ) posted Fri, 07 September 2012 at 11:11 AM
You go to "Groups" tab and left-click once on the icon at left, that will hide it.
PoseRay will only export the groups that are visible (it skips hidden ones)
darquevision ( ) posted Fri, 07 September 2012 at 12:17 PM
 i have tried that seems to only keep the file hidden however the actual file still contains the "full" file. i thought they were skipped but when checking "groups" they are there and can be unhidden. the exported obj it is still full as well
ty for the response
CyberDream ( ) posted Fri, 07 September 2012 at 12:40 PM
I checked before posting (in case memory failed) and for me it only exports visible Groups and the material associated with that group (you don't have to hide both).
I am using version 3.12.2.456 which is current non-beta version
darquevision ( ) posted Fri, 07 September 2012 at 1:39 PM
i just checked mine and i am running the beta version- that might be the issue then.
is the non bata vision available for free also?
again thank you for the responses
CyberDream ( ) posted Fri, 07 September 2012 at 2:58 PM
I just tried the beta and group export does not work the same as regular.
The regular version is also free at
https://sites.google.com/site/poseray/home
darquevision ( ) posted Fri, 07 September 2012 at 3:11 PM
awsome- ty for the link.
plus i am glad it was just due to the version i was using rather than my lack of knowledge.
again ty i am going to dl it now.
darquevision ( ) posted Fri, 07 September 2012 at 3:38 PM
i just realized after looking a bit closer- there is an option "remove non visible groups" in groups that sorted it out- it also worked fine in beta.
at any rate ty for your help
