Sat, Feb 15, 7:00 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Subject: cr2 bloat, How big is too big?
Paloth ( ) posted Fri, 14 September 2012 at 4:15 AM · edited Thu, 19 September 2024 at 11:59 PM
I attempted to create a figure that would use falloff spheres compatible with Daz Studio and all versions of Poser, with corrective JCMs to optimize bending. I ran into various problems along the way that destroyed my hopes of achieving wide compatibility. Though the results were good in Poser Pro 2012-Poser 8, the JCMs were broken when IK was used. Also, the JCM approach made full body morphs very difficult to optimize since each FBM required it's own JCM set.
One consequences of all of these morphs was that I began to suffer from cr2 bloat, exceeding 47 megs at its nadir. When I decided to go with weightmaps, I deleted the JCMs to make a clean start, but I retained the head morphs, of which there are 80. The cr2 bloat has decreased, but it remains substantial, at 31 megs. Is this excessive considering the 80 head morphs? Is there a practical limit to how large a cr2 should be?
Teyon ( ) posted Fri, 14 September 2012 at 4:28 AM
Are you using PMD's? They were designed to help with this very thing I think. If you're not using PMD's and everything is being stored in the CR2, you're going to see the file size jump due to the large number of morphs, so in cases like that - 31 megs is probably normal. Heck, it's probably pretty low.  If you're not using PMD's try saving out a version that does and compare the file sizes of the CR2.
Personally, I don't really care how large a Cr2 is in file size as long as the figure works. It may take longer to load but that's a trade off I'm happy to make if everything about the figure is flawless.
Paloth ( ) posted Fri, 14 September 2012 at 4:40 AM
No. Part of the quest for wide compatibilty involved storing the morphs in the cr2. That's all beside the point now, though.
It's now 3.8 Megs. That's a huge improvement*.*
I'll probably end up storing the morphs in the cr2 if I don't run into a file size limitation when it comes to distribution. *
vilters ( ) posted Fri, 14 September 2012 at 4:57 AM
I also work a lot with fullbody morphs, and ha-ha-, yes they do increase file size a lot.
But PP2012 SR3 has a "partial" solution.
You can selectively delete useless parts from a full body morph.
Example.
A full body morph creates a dial in each and every group of your figure.
Are they all needed? Was each and every group changed/morphed????
Each full body morph creates a dial in the fingers, fingertipstips, thumbs, in the toes, in the eyeballs or cornea's to name a few.
Was something changed/morphed in the FBM there??
If no?
You can safely delete all useless dials from all groups that have "no change" in a particular FBM.
Goto the FBM dial in the parameters palette click the little arrow behind it and click delete.
UNCHECK all groups you want to maintain in that FBM.
Click OK.
All useless dials from that particular FBM are deleted.
Happy Posering
Tony
Winterclaw ( ) posted Fri, 14 September 2012 at 7:03 AM
I think there's also a python script that strips out all unused morphs for you.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
vilters ( ) posted Fri, 14 September 2012 at 7:17 AM
Does that script not strip out all dials that are at a ZERO value?
That gives quite a different "unwanted" result then..
Paloth ( ) posted Fri, 14 September 2012 at 7:50 AM · edited Fri, 14 September 2012 at 7:52 AM
I found a script for morph removal, but it missed most of the morphs. Poser Pro 2012 SR3's morph removal check list was a little tedious because there were about 200 morphs. Morph Manager can remove all morphs from a selected part at once. Even so, the cr2 still had some JCM related junk ithat I was able to clear with Pose File Editor.
vilters ( ) posted Fri, 14 September 2012 at 8:05 AM
WHAW, did you have 200 FBM to go through????
Oh, Lord, :-) :-) :-)
And?? What is the final score?? The resulting file size??
Paloth ( ) posted Fri, 14 September 2012 at 8:27 AM · edited Fri, 14 September 2012 at 8:28 AM
*I think it was 200 PBMs, all joint controlled, including the digits of the hands. That's hard to believe, but I don't want to go back and recount. Anyway, the cr2 has gone from 47 megs to 3.
I'll have plenty of the JCMs to choose from when the WMs can't get the job done.
vilters ( ) posted Fri, 14 September 2012 at 8:34 AM
Now that is lean and clean... :-)
Housekeeping, don't you just LOVE it????? :-)
Paloth ( ) posted Fri, 14 September 2012 at 8:37 AM
I'm screwing up today. It was a 3 meg cr2 with PMDs, but it's actually 31 megs with all the head morphs loaded.
dadt ( ) posted Fri, 14 September 2012 at 8:50 AM
The file sizes don't seem to be too large. I just checked my files and my characters using V4 as a base are on average 43 meg, with one at 58 meg. These all include dynamic hair.
markschum ( ) posted Fri, 14 September 2012 at 12:26 PM
The cr2 is simply a text file, and they often contain lots of white space which makes the file big. For disk space savings turn on the option for Poser to use compressed files. (or use the included script to compress the file.
Paloth ( ) posted Mon, 17 September 2012 at 12:50 AM
Thanks for the responses and the reminder about compression.  I'm going to forge ahead without worrying to much about the meg count.
