Yep, you would have been sent an email but if you go to your account at the e-on website click on Your Orders, Download Links, Serial Numbers and Invoices link and then Vue 10.5 it will take you to a page where you can have the download link emailed to you.
With Vue Infinite 9.5 I didn't install it and when I came to install Vue Infinite 10 I had to install 9.5 first. E-on said they were going to fix this but I've no idea if Vue Infinite 11 will be the same or not.
I created a Yahoo email account just so I could receive emails from both e-on and Cornucopia3D. Contact e-on tech support if the Vue 10.5 download link for your online account has expired.
Quote - Same place in your user account, next to Vue 10.5, there should be a "Send serial" button.
Thank you! That worked.
Kind of a confusing setup. When I started the program, it didn't ask me to put in a serial. It already had the Vue 10 serial I used to download 10.5, and said it was wrong. If it had been blank, it might have occurred to me that I needed a new serial.
That would make sense. I always deleted my previous Vue and removed any reference to it in the registry. So there was nothing in the blanks when I installed the newer Vue.
I never delete the previous version until I am convinced the new version is stable enough for use.
On OS X each installation seems to be independent.
I've just started using Vue 10.5 on Windows 7, so will find out in November(?) what happens when I install a new version.
e-on Software should fix this kind of thing in testing. It's not very professional! It shouldn't be necessary to hack the Windows registry...
Quote - It shouldn't be necessary to hack the Windows registry...
That's just something I do. modo and Carrara and Hexagon and .... all leave stuff in the registry. I like to have a clean system before I install a previous version of an app, so my associated file icons and file paths all work correctly for one thing.
I have Vue Infinite 10, and I'm under maintenance. I gather that means I can download 10.5 free if I want.
Should I? Is it an improvement? Is it stable?
And how, exactly, do I get this upgrade?
E-on may well have sent me an e-mail explaining all this, but I just found out Gmail is blocking E-on as spam.
