Sat, Feb 1, 10:05 AM CST
Subject: Vue Infinite 10.5?
randym77 ( ) posted Sat, 15 September 2012 at 10:12 AM · edited Sat, 01 February 2025 at 10:04 AM
I have Vue Infinite 10, and I'm under maintenance.  I gather that means I can download 10.5 free if I want.
Should I?  Is it an improvement?  Is it stable?
And how, exactly, do I get this upgrade?
E-on may well have sent me an e-mail explaining all this, but I just found out Gmail is blocking E-on as spam.
Janl ( ) posted Sat, 15 September 2012 at 6:42 PM
Yep, you would have been sent an email but if you go to your account at the e-on website click on Your Orders, Download Links, Serial Numbers and Invoices link and then Vue 10.5 it will take you to a page where you can have the download link emailed to you.
With Vue Infinite 9.5 I didn't install it and when I came to install Vue Infinite 10 I had to install 9.5 first. E-on said they were going to fix this but I've no idea if Vue Infinite 11 will be the same or not.
ShawnDriscoll ( ) posted Sat, 15 September 2012 at 7:29 PM
I created a Yahoo email account just so I could receive emails from both e-on and Cornucopia3D.  Contact e-on tech support if the Vue 10.5 download link for your online account has expired.
randym77 ( ) posted Sat, 15 September 2012 at 9:36 PM
Thank you kindly!
Downloading now...
randym77 ( ) posted Sat, 15 September 2012 at 10:18 PM
Downloaded and installed, but I can't run the program.  I get a "bad serial number" error message.
Even though it accepted that very same serial number before allowing me to download the program.  Sigh.
bruno021 ( ) posted Sun, 16 September 2012 at 4:32 AM
Same place in your user account, next to Vue 10.5, there should be a "Send serial" button.
randym77 ( ) posted Sun, 16 September 2012 at 7:25 AM
Quote - Same place in your user account, next to Vue 10.5, there should be a "Send serial" button.
Thank you!  That worked.
Kind of a confusing setup.  When I started the program, it didn't ask me to put in a serial.  It already had the Vue 10 serial I used to download 10.5, and said it was wrong.  If it had been blank, it might have occurred to me that I needed a new serial.
bruno021 ( ) posted Sun, 16 September 2012 at 1:31 PM
Guess the confusion comes from the fact that both apps are Vue 10, only the build nbr is different, so your machine thought you were reinstalling Vue 10.
ShawnDriscoll ( ) posted Sun, 16 September 2012 at 5:58 PM
That would make sense.  I always deleted my previous Vue and removed any reference to it in the registry.  So there was nothing in the blanks when I installed the newer Vue.
penboack ( ) posted Tue, 18 September 2012 at 8:52 AM
I never delete the previous version until I am convinced the new version is stable enough for use.
On OS X each installation seems to be independent.
I've just started using Vue 10.5 on Windows 7, so will find out in November(?) what happens when I install a new version.
e-on Software should fix this kind of thing in testing. It's not very professional! It shouldn't be necessary to hack the Windows registry...
http://penboa.deviantart.com/
bruno021 ( ) posted Tue, 18 September 2012 at 6:03 PM
There's no need to hack anything. But as for Windows or Vue knowing your serial by itself...
ShawnDriscoll ( ) posted Tue, 18 September 2012 at 6:41 PM
Quote - It shouldn't be necessary to hack the Windows registry...
That's just something I do.  modo and Carrara and Hexagon and .... all leave stuff in the registry.  I like to have a clean system before I install a previous version of an app, so my associated file icons and file paths all work correctly for one thing.
