Forum Moderators: Wolfenshire
Photoshop F.A.Q (Last Updated: 2025 Feb 18 8:03 am)
pchoate,
If you got the regular Photoshop CS6, it does not have the manipulation tools. You need the extended version
This one: http://www.adobe.com/products/photoshopextended.html
Not this one: http://www.adobe.com/products/photoshop.html
I have 3D fine, I can do all of the 3D stuff on a 3D model with textures, but to manipulate the object in 3D space I have to use "coordianates -- ther are no tool to rotate, scale, or move the object. There used to be, and it was working fine, but suddenly stopped working, as if I had inadvertanly turned something off! But I sure can't figure out what, if anything, I did to mess this up!
Thanks. SWAMP. I guess maybe CS6 is laid out a little bit different. Under View|Show, there is no option for 3D Axis. There IS an option for "See other options..." and it looks as if alll of the 3D setup is under that option. In my case, all of the 3D options were still turned on.
I wish it had been that simple, I'm still trying to figure it out. All was working fine a couple of weeks ago. I am on the brink of just re-installing PhotoShop.
I only have CS4 and it's not extended BUT I know visibility of menus and panels frustrated the hell out of me.
Edit > Menus > Panel Menus
Open up the 3D dropdown and check the visiblily of the items you aren't seeing.
Also, which Workspace are you using? One of the presets or did you create your own? You might have picked a Workspace which has certain menus/panels invisible.
PLEASE, can SOMEBODY help. This MUST be an easy fix, because everything worked FINE 10 days ago! I think (but I am really not sure, and I don't want to sound accusitory) that the problem started with a recent Adobe "upgrade" download.
PLEASE help if you can!
Maybe so, that would be great. I expect it is something that simple, something that I am just not seeing for the "trees". In the case of this particular option, however, PS will not let me select it, like it is "greyed out". I can hover over it and even get a tool-tip description of the button, but I can't check it "on".
Quote - try the 3d mode tools (manips) in upper tool bar. in earlier versions they were at the bottom of the side tool bar.
i agree.it is useful .
Happy life can't apply colors to a drawing of the render farm !
Well, I thought I'd thank everyone and close the topic here. Indeed, my problem WAS the video board/driver. But, once I had screwed it up, nothing I tried seemed to correct the problem. My son finally convinced me to purchase a new NVIDIA Quadro. Evpensive upgrade, but everything works fine with the new card.
I hope this turns out to be "duh?" -- a stupid question with an obvious answer. But I have searched Adobe and the 'net and have not found my problem described.
The problem is that I have no tools to manipulate 3D objects (figures, lights, cameras) in PhotoShop (using CS6). All of the tutorials demonstrate how easily these objects can be manipulated using the little 3-axis widget. But I don't have any 3-axis manipulator tool. In fact, the ONLY way I've been able to manipulate these objects is manually with the "coordinates" tools.
Please, can anyone help?
Paul
