Sat, Nov 2, 12:18 PM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 01 10:58 pm)
Subject: Karina Ionova V4 Genitals Skin Problem
xpdev ( ) posted Tue, 25 September 2012 at 11:11 AM · edited Sat, 02 November 2024 at 10:33 AM
hello guys
I downloaded the "A new genital prop for V4, A4, G4, S4 & L3" from  Karina Ionova that seems to be the best around
but I have a problem on his skin lips, I can not understand (there is a trans map) how to match the external skin of the lips with the skin of V4
can someone explain to me how to do?
I think you need to download the package to help me.
Thank you.
http://www.sharecg.com/v/42779/3D-Model/A-new-genital-prop-for-V4,-A4,-G4,-S4,-L3-&-MGPT-f
here is the trouble.
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
basicwiz ( ) posted Tue, 25 September 2012 at 11:59 AM
Select the prop.
Go to the material room.
Using the select texture drop down, select the torso texture you are using for V4.
Click OK.
xpdev ( ) posted Tue, 25 September 2012 at 12:13 PM
Thanks, but i know this way.
with this way Internal lips doesen't match with reality.
anupaum ( ) posted Tue, 25 September 2012 at 4:17 PM
Maybe you can use Snarly's EZ Skin shader for that.  I've got no need for texturing labia, but I've used EZ Skin on wings.  That might solve your problem.
TZORG ( ) posted Tue, 25 September 2012 at 4:22 PM
Someone has probably made a procedural labia material. I saw bagginsbill making some pretty nice looking wood
It's not the tool used, it's the tool using it
SamTherapy ( ) posted Tue, 25 September 2012 at 5:36 PM
Quote - Someone has probably made a procedural labia material. I saw bagginsbill making some pretty nice looking wood
:lol:
Post of the week!
hborre ( ) posted Tue, 25 September 2012 at 8:09 PM
Quick, point BB to this thread!!!
primorge ( ) posted Tue, 25 September 2012 at 11:37 PM
I knew it was only a matter of time before the cat-calling would start! now I feel justified in my hysterical laughter... " I've got no need for texturing labia, but..."
xpdev ( ) posted Tue, 25 September 2012 at 11:54 PM
Thanks to everybody, but the prop has no labial in material room, only a generic "genitals" which include al that you can see in my rendering, internal ed external vagina.
xpdev ( ) posted Wed, 26 September 2012 at 4:29 AM
Noboby use this product ?
Ok, i'm not able to find a very good vagina for V4, kindly suggest me a product that has the morph suit for sex scenes and whose skin can be perfectly compatible with any skin I use.
thanks
bobbesch ( ) posted Wed, 26 September 2012 at 4:58 AM
I'd recommend EZskin2 for this task. Load V4 and the prop. Select the prop, go to the edit tab, select the material you want to edit, select a material from the drop down menu and apply. Skin or innermouth, since the labia minora are partly covered by mucosa. If it still does not blend in, i would get rid of the texture map and use a part of the orignial skin map your'e using.
edit: No need to get giggly, it's just genitals, isn't it?
xpdev ( ) posted Wed, 26 September 2012 at 5:42 AM
hi **bobbesch**.
it's impossibile to select the " Karina Ionova" object with EZSkin2, always select V4.
here the picture where i can find " Karina Ionova"
how can i solve it ?
xpdev ( ) posted Wed, 26 September 2012 at 5:45 AM · edited Wed, 26 September 2012 at 5:47 AM
and this is what i get when i launch Ezskin, EZ always see V4 instead of "Karina Ionova V4 Genitals"
Snarlygribbly ( ) posted Wed, 26 September 2012 at 5:48 AM
You can trick EZSkin into using the prop: just select the prop and then choose the 'Use Hair Prop' option. Yes, I know it isn't a hair prop, but we don't need to let EZSkin know that do we ;-) EZSkin is dumb: it'll believe what you tell it.
Then assign the 'skintrans' shader to it
Free stuff @ https://poser.cobrablade.net/
xpdev ( ) posted Wed, 26 September 2012 at 6:06 AM
Ok, i understand how work with "Karina Ionova V4 Genitals" and EZSKin.
now there is the problem for lips skin.
this is the original skin for lips from builder "karina".
xpdev ( ) posted Wed, 26 September 2012 at 6:07 AM · edited Wed, 26 September 2012 at 6:10 AM
and this is the template for the skin.
xpdev ( ) posted Wed, 26 September 2012 at 6:09 AM
Karina wrote me:
"To match it (original skin for lips) to your figure's texture, you must play around with the HSV in an image editor until it matches."
but i really don't know how do it !!!
any ideas ?
many thanks.
bobbesch ( ) posted Wed, 26 September 2012 at 6:37 AM
You need photoshop or something similar for the next step. The template is 180 degrees rotated, so you will want to turn it first. Load the skin map of your choice and the template in a new layer. Tweak the size of the template, so it fits your map. To cover the whole template area with skin, i used the patch tool. Crop the area of your map that lies within the area of the template, rotate 180 degrees and save as a new map for the prop.
xpdev ( ) posted Wed, 26 September 2012 at 6:43 AM
hum... really complicated for me... i'm not used to work with textures.
may you make for me a tutorial ?
i haven't photoshop
sorry for the request.
bobbesch ( ) posted Wed, 26 September 2012 at 6:51 AM
Do you have other software for image processing? Gimp is quite powerful and free, but takes a while to get used to, as does every versatile tool.
xpdev ( ) posted Wed, 26 September 2012 at 7:04 AM
Yes, i have GIMP but i use A few
bobbesch ( ) posted Wed, 26 September 2012 at 7:39 AM · edited Wed, 26 September 2012 at 7:46 AM
> Quote - Yes, i have GIMP but i use A few
I don't use GIMP, but here is what i do in photoshop:
  1. Load the texture
bobbesch ( ) posted Wed, 26 September 2012 at 7:41 AM · edited Wed, 26 September 2012 at 7:46 AM
2. The template area is slightly bigger than the torso map, so i make the workspace bigger at the bottom and use the stamp and the patch tool to get that area covered.
bobbesch ( ) posted Wed, 26 September 2012 at 7:43 AM · edited Wed, 26 September 2012 at 7:47 AM
3. Load and turn the template in a new layer upside down, resize when necessary and place over the right spot of the map.
xpdev ( ) posted Wed, 26 September 2012 at 7:44 AM
i'm following you, many thanks.
bobbesch ( ) posted Wed, 26 September 2012 at 7:44 AM · edited Wed, 26 September 2012 at 7:47 AM
4. Select the area of the template
bobbesch ( ) posted Wed, 26 September 2012 at 7:45 AM · edited Wed, 26 September 2012 at 7:47 AM
5. Delete the layer with the template
bobbesch ( ) posted Wed, 26 September 2012 at 7:48 AM
6. Crop to selection, turn upside down and save as map for the prop
xpdev ( ) posted Wed, 26 September 2012 at 7:53 AM
are you using photoshop ?
bobbesch ( ) posted Wed, 26 September 2012 at 8:01 AM · edited Wed, 26 September 2012 at 8:08 AM
> Quote - are you using photoshop ?
Yes, this is CS5. This are the results for skin and innermouth shaders:
xpdev ( ) posted Wed, 26 September 2012 at 8:15 AM
Ok, many many thanks.
bobbesch ( ) posted Wed, 26 September 2012 at 9:22 AM
Your'e welcome.
xpdev ( ) posted Wed, 26 September 2012 at 10:18 AM · edited Wed, 26 September 2012 at 10:19 AM
not have to hurt, but I was hoping for a much better result.
unfortunately I have to point out that there is not a model of well-functioning vagina for V4.
Each product has its strengths, but just can not seem to find one that has a good success, at least I'm talking about those with moprh suitable for sexual activity.
I believe I have tried all of them (with a lot of money down the drain) are accept any further advice on any type of vagina for V4 that has a good outcome and accept the maps for V4.
thanks
primorge ( ) posted Wed, 26 September 2012 at 1:50 PM · edited Wed, 26 September 2012 at 1:52 PM
Buy the AONEDOLL-Mrs Nelson figure at content paradise (or @ the unmentionable place)... she's a pretty good figure for what your trying to do, although she is decidedly less idealized than V4, she has all kinds of nether regions options built in- http://contentparadise.com/productdetails.aspx?id=15386
Additionally you might want to check out poseidentech's V4 products, he has some custom .Cr2 characters that seem to be what your looking for-
http://www.poseidentech.com/Dounya.htm
...not that I do much Hustler style poser renders but...
Nice Tutorial there, bobbesch.
Hope I didn't violate any Rendo rules with those links...
