Thu, Feb 27, 2:11 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 1:25 am)
Subject: Poser Tool Box - Ryan Face Putty Control Cage?
pitklad ( ) posted Wed, 26 September 2012 at 12:42 PM · edited Wed, 26 February 2025 at 11:07 PM
is there a control cage for Ryan? it says he is not supported figure
Also is there a way to create a cage for him using the available ones?
My FreeStuff
PhilC ( ) posted Wed, 26 September 2012 at 3:59 PM · edited Wed, 26 September 2012 at 4:11 PM
From the instructions:-
Over 70 control cages are included with the program. This should cover the bulk of the most popular figures. If you find that your figure is not supported you have these options:-
  1. Adapt one of the existing cages. Simply reposition/scale and export out the OBJ file. Follow the file name convention [figureOBJfilename-CAGE.obj] You could also use the Vertex Magnet tool to good effect.
  2. Use a 3D modeling program to adjust an existing cage.
  3. Make your own custom cages using a 3D modeling application see also the information on using the Vertex Magnet tool.
Cages should be symmetrical
Very little finesse is required it does not need to be exact. You could make one for just the front of the face with a few more or a few less vertices.  Just be sure to follow the naming convention. For Ryan that will be P8Ryan_HR-CAGE.obj and for Ryan2 that will be Ryan2_HR-CAGE.obj .
Please let me know if you get stuck but it should only take you a couple of moments.
pitklad ( ) posted Wed, 26 September 2012 at 4:05 PM
Cool! that means I can make my own, so I only have to match the Figures obj name with the cages name and put it on the folder where the other cages are?
This should be easy, thanks for the responce!
My FreeStuff
PhilC ( ) posted Wed, 26 September 2012 at 4:13 PM
Yep. I made it very flexible. Plus if you look at the Vertex Mags section you can effectively apply the same principle to any part of the body.
pitklad ( ) posted Wed, 26 September 2012 at 4:23 PM
wow! this makes morphing inside poser a whole new story! very cool!
My FreeStuff
