As you can see in the last picture - available free physical RAM is 1 MB. This means that Windows has to free up RAM which other programs have allocated. (RAM available). This is normal Windows behaviour.
PP2012 does use all of the memory when it needs it. I have done scenes which use 24GB and does so without swapping (I have 32GB in my system)
It does seem that Poser (and any other programs you have running) is eating up your hard mem.
Bear in mind virtual memory is always being used, even when the memory that is required by all running processes does not exceed the volume of RAM that is installed on your system.
What I'd like to know is why Firefox consumes up to half a gig of memory for a damn web browser... but that's another issue.
It's not Poser, it's your system eating the memory, as it says that it has created over 800.000 handles. The usual remedy is to start rendering as a separate process (well, it is Poser after all, when the render is finished the handle mem is not freed up). Or you can restart Poser after every so many renders, but that's less convenient.
We had a thread on this some time ago.
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
Hi,
thanks a lot! Yes, it looks like that there is in fact only very little RAM free. This could be due to a Windows bug, I found some threads concerning issues with NUMA CPUs (I wonder if I have one?), for example here: http://support.microsoft.com/kb/2155311/en-us
Rendering in a separate process (for example using Queue manager) seems to be a good solution, which will have the additional benefit that I can further tweak the scene while the render is in progress...
Re the browser memory consumption: I usually have loooots of tabs open. Once when I closed a browser but took notes about the pages I counted more than 200...
Best regards,
Michael
Render as a seperate process is an option in the preferences, but you need Queuemanager indeed to continue working in Poser while rendering.
is it possible that Poser Pro 2012 does not use all available memory? For some scenes, Poser suddenly starts high disk activity and CPU usage goes down at the same time. This is usually an indication of swapping. However I have lots of RAM free, as my Windows task manager shows:
Is there some Poser setting or Windows setting to allow usign all RAM?
(I'm using Windows 7, 64 Bit and Poser Pro 2012, 64 Bit)
Best regards,
Michael
