Wed, Feb 12, 11:58 PM CST
Subject: Unrendered parts in picture.
Jacobus01 ( ) posted Sun, 07 October 2012 at 12:41 PM · edited Wed, 12 February 2025 at 8:05 PM
A part of a scene I'm working on.
The problem is every time I render it there is this black unrendered area on the amplifier, always in the same place, no matter what camera/light settings I use.
The object has been rendered succesfully in a previous image.
If anyone has an idea of what I'm doing wrong and how to correct it, shoot:)
Tnx
rokket ( ) posted Sun, 07 October 2012 at 2:03 PM
Are the head and cab separate props? There is a wierd buldge at the bottom front of the head that I don't think should be there.
If they are separate props, you might have to tweak where the cab is meeting the head. If they are not separate props, then I am lost.
This is a pic I found of a mkII amp head, which I believe is the JCM head you have in the render. See what I mean about the front bottom of the head?
raven ( ) posted Sun, 07 October 2012 at 2:11 PM
Try selecting the amp and uncheck smooth polygons on the properties tab.
Jacobus01 ( ) posted Sun, 07 October 2012 at 2:36 PM
Yes, the smooth polygons option was the problem, I turned it off and everything is fine now.
The model I was going for with the amp was the JCM800;)
