Sun, Jan 5, 9:33 AM CST
Subject: EZSkin and make-up mask
pokeydots ( ) posted Mon, 08 October 2012 at 2:34 PM · edited Sun, 05 January 2025 at 9:28 AM
I have searched, and have found some info on how to use mask in poser, but what I can't find is how to hook up a mask, for blush and shadow, when using ezskin, so that it uses the scatter node. I have created the mask, but not sure how or where to plug it in. It is a grey scale mask, and I need to have a node that lets me pick the color for the blush and or eyeshadow. Does that make sense? lol
Here is the screen shot of the (head) material room settings, after I ran EZSkin.
Any help is much appreciated.  :)
Sorry the image is small but here is a link to view the larger image
https://docs.google.com/open?id=0ByxtcdfasIUqRlBFZk8zdDFwWHc
Poser 9 SR3  and 8 sr3
Processor Type:  AMD Phenom II 830 Quad-Core
Hard Drive Size:  1TB
Processor - Clock Speed:  2.8 GHz
Operating System:  Windows 7 Home Premium 64-bit
Graphics Type:  ATI Radeon HD 4200
System Ram:  8GB
wimvdb ( ) posted Mon, 08 October 2012 at 3:01 PM
EZSkin has an additional script installed which is called Nodegrabber.
This script allows you to make an XML file which you can then use in EZSkin2 as a Special Effect.
It is in an experimental phase, but it works well. Unfortunately there is no documentation for it (yet). But it is not so difficult to figure out.
Here is what I remember:
You make your blend setup in simple node setup (preferably only with the nodes you need for the blend with image map). Then in the script you select which input node of the blend node is the effect and what type of map the blend is for (diffuse, bump or other)
Then you press the button to create the xml file and you can import it in EZSkin2.
It has been a while so maybe I am missing a step. But with a little experimentation you can get it done
pokeydots ( ) posted Mon, 08 October 2012 at 3:10 PM
I'll have a look and see if I can figure it out, Thanks
System Ram:  8GB
pokeydots ( ) posted Mon, 08 October 2012 at 3:55 PM
Well I have no idea how I did it, but your suggestion worked :)  Thank you !
System Ram:  8GB
wimvdb ( ) posted Mon, 08 October 2012 at 4:09 PM
Glad you got it to work. It is a bit limited, but integrates very well into the EZSkin2 nodes
pokeydots ( ) posted Mon, 08 October 2012 at 6:10 PM
Now that I have that one figured out, is there a way to add a second mask, to the first one? I have one for eye shadow, and I want another one for the blush, but I want to be able to control the color and strength seperately. Thanks
System Ram:  8GB
wimvdb ( ) posted Mon, 08 October 2012 at 6:27 PM
I don't think that is possible in this version of Nodegrabber.
It always starts from scratch, so the second one will eliminate the first one.
Snarlygribly said he was thinking of making a Pro version of this, but I have no idea when that would be available
pokeydots ( ) posted Mon, 08 October 2012 at 6:39 PM
Maybe someone will know how to set it up by hand, there has to be a way to use a blender node or something, at least I hope so :)
System Ram:  8GB
wimvdb ( ) posted Mon, 08 October 2012 at 6:44 PM · edited Mon, 08 October 2012 at 6:45 PM
By hand it is easy. Just use the output of the first blender as input of the second blender. The output of the first blender node is like a new texture where you put the second effect on.
Automating it with different combinations is a challenge
 If you want to see very complex ones of this method. Go to ShareCG and look for red_viper. He has easyshader3. This one adds scatter, wet skin, tanliines, blushes, soap and other things together.
pokeydots ( ) posted Tue, 09 October 2012 at 11:24 AM
Going to go look  for red viper, I messed around for awhile last night and your right, I can't figure out how to control them seperately. Thanks
System Ram:  8GB
