If the texture has an eyebrow then transmapping is not needed. simply use the "browgone" morph or make the upper eyebrow disappear. The only part that will be transmapped in this case is the eyelashes. in regards to the image above, just restore the eyebrow (the settings for the eyebrow should match the face)
As I said .. the eyebrow is a serperate section of the head map. that should be the same color as the head. eyebrow 2 at the bottom of the list is nothing. It is a left over. The upper eyebrow is the only item that should have a transparancy applied.that map should be applied to the head like the lashes. Hope that clears it up.
