Mon, Nov 25, 1:37 PM CST
Subject: Genesis + POSER
Steeleyes101 ( ) posted Sun, 14 October 2012 at 9:14 AM · edited Mon, 25 November 2024 at 11:50 AM
Hello all and hope your weekend was a good one
I was wondering a few things, but will try not to bog you down with to many questions at once.
1, DAZ put out a promotion copy of the new plug-in that allows Poser users to use the new Genesis figures as Im sure everyone already knows.
My question is; has anyone installed and used it yet; and if so were there any install problems that I should keep an eye out for?      I have Poser 9 and am also about to install Poser 2012.
2,  Befor I go on a very dumb question.   Is V5 M5 the same as Genesis???
3,  My other concern is clothing.  If I do have the Genesis figure what about clothing.          If Genesis figures were orig. designed for DAZ Studios.....   How do I get the clothing for them into Poser, or do I first have to get and install DAZ Studios in order to use them?????
Thats it for now but expect many more questions :)
Thanks much Steel.
ToxicWolf ( ) posted Sun, 14 October 2012 at 9:39 AM
Attached Link: Start Here
That thread should help get you started.
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
http://www.toxicwolf.com
mgtcs ( ) posted Sun, 14 October 2012 at 12:06 PM
I have downloaded and installed the new plugin that allows Poser to use the (in)famous Genesis character, but it was a dreadful experience.
For starters, there is the very fact that you have to install a plugin in the first place. The only reason that this is so is because Daz wanted to make a play for the market by attempting to lock in their customers into their platform by using proprietary encrypted formats. This, in and of itself, gives you a bad taste before you even start using the damn thing.
Second of all, once I actually installed the plugin, it simply did not work. Instead, it showed a series of error messages saying that other programas were required for the plugin to work and it actually made Poser crash!
Finally, although it was relatively easy to uninstall, it still did leave a lot of crap behind that I had to remove manually. Maybe there is a very complicated way of configuring and setting up the plugin so that it will work, but who needs the hassle?
In a nutshell, I love the Daz characters and products in general, but I am staying away from that plugin altogether, and I recommend everyone else to do the same. I am also avoiding the Genesis line of characters, unless they make it 100% Poser compatible, such as it is the case of Victoria4.
I will post it on my last image at my gallery!
Medzinatar ( ) posted Sun, 14 October 2012 at 12:21 PM
I had absolutely no problem installing and was able to bring up Genesis figure immediately.
I did notice that the SSS shader on V5 does not have separate scatter groups by default, giving a blue tinge around mouth, but is easy to assign a new scatter group number.
I did have problem at first with converting poses for SubDragon, but is separate issue and solved now.
All the Genesis clothing in .duf format converts and fits easily so far
EZskin2 can be configured to work for Genesis with small effort
nobodyinparticular ( ) posted Sun, 14 October 2012 at 12:35 PM
I had no problem installing. It does works as stated above. Not everything for Genesis has been converted yet to work in the Poser interface. I'm told that with the latest version of Daz studio you can do this yourself.
hborre ( ) posted Sun, 14 October 2012 at 12:37 PM
It is best to follow the original thread posted by Toxic Wolf.  There is far more information there and it would be redundant and confusing if multiple threads keep reiterating what is already common knowledge.
icprncss2 ( ) posted Sun, 14 October 2012 at 12:50 PM
Genesis is the base figure that an be morphed into male, female, child or other shapes.
All other shapes including V5, M5, and S5 are nothing more than moprh sets.
LaurieA ( ) posted Sun, 14 October 2012 at 6:22 PM · edited Sun, 14 October 2012 at 6:22 PM
My installation was a breeze and it worked perfectly. However, I DID read all of the instructions and the Daz thread before I installed. Most obviously, others did not do the same ;).
LaurieA ( ) posted Sun, 14 October 2012 at 6:26 PM · edited Sun, 14 October 2012 at 6:26 PM
Forgot to mention that in addition to the SSS shaders all in the same group, there is a known issue with the library and the plugin (Pro users need to set the library to external in preferences to avoid this). For now, there is not a workaround for Poser 9 users but Daz has been made aware of the problem.
rbratche ( ) posted Mon, 15 October 2012 at 9:46 PM
Crashed my Poser 2012 and i had to reload from scratch:( So far DAZ is only digging the hole deeper:(
mgtcs ( ) posted Mon, 15 October 2012 at 10:21 PM
I tottaly agree with you! Fortunately my Huby was able to removed it!
