Tue, Nov 19, 7:45 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Setting "shadow " parameter if a light
Anthony Appleyard ( ) posted Sun, 21 October 2012 at 7:21 AM · edited Tue, 19 November 2024 at 7:42 AM
import poser
import string
import aasubrs
reload(aasubrs)
scn = poser.Scene()
for a in scn.Actors():
    if a.IsLight():
        print "found light ",a.Name()
        a.SetShadow(1)
        a.Set??????????(0.5)
poser.ProcessCommand(1559)
#scn.DrawAll();
In this Python script, as run under Poser 7, what Poser Python function should I call to set the parameter called "Shadow" in a light's parameter box in Poser 7?
PhilC ( ) posted Sun, 21 October 2012 at 7:40 AM · edited Sun, 21 October 2012 at 7:42 AM
In Poser 7 I see the checkbox "Shadows".
The Python method is:-
SetShadow(1) #shadows off
SetShadow(0) #shadows off
The dials are set with:-
SetShadowBiasMax(value) # float value
SetShadowBiasMin(value) # float value
SetShadowBlurRadius(value) # float value
If I recall correctly the Properties panel will not update unless you manually force it by switching to the Parameters panel and back again.
Anthony Appleyard ( ) posted Sun, 21 October 2012 at 7:58 AM · edited Sun, 21 October 2012 at 7:59 AM
I am trying to use Python to alter the parameter "Shadow" which is at the top of the list in this image. I usually use Poser 7.
Dizzi ( ) posted Sun, 21 October 2012 at 10:20 AM
p=a.ParameterByCode(poser.kParmCodeDEPTHMAPSTRENGTH)
p.SetValue(0.5)
markschum ( ) posted Sun, 21 October 2012 at 11:06 AM
In Poser 7 you can use lites = scn.Lights()  instead of getting and filtering the actors list.
Anthony Appleyard ( ) posted Sun, 21 October 2012 at 11:50 AM
Thanks. It works.
import poser
import string
import aasubrs
reload(aasubrs)
scn = poser.Scene()
    if a.IsLight():
        a.ParameterByCode(poser.kParmCodeDEPTHMAPSTRENGTH).SetValue(0.5)
        a.SetShadow(1)
#scn.DrawAll
