Mon, Dec 23, 7:12 AM CST
Subject: Vue 11 is here :)
Mazak ( ) posted Tue, 23 October 2012 at 2:16 PM · edited Mon, 23 December 2024 at 7:07 AM
Dear Bodo,
Vue 11 Infinite, a major upgrade to one of your products under maintenance, will soon be shipping. As part of your maintenance contract, you will receive this new product at no charge.
We have also prepared a pre-release version of this product. If you like, you can download this pre-release version right away by following the instructions in this e-mail.
New features available in Vue 11 Infinite include:
Key features of Vue 11 include faster rendering, Illumination Caching, terrain and EcoPainter improvements, 360° population, interactive EcoSystem population, as well as particles. But it's not just particles, it's a new concept of particles! With Vue 11, you can do all the standard stuff that particles are good at, but you can also do a lot more. Rather than creating simple emitters, and having particles grow out of them, we designed a new way of handling particles that is specifically well suited for Digital Nature.
Here is a shortlist of some of the important new features included in Release 11 of Vue:
  • EcoParticles: This new technology is ideal for the creation of animated rain, snow, waterfalls, explosions, fire, smoke, tornadoes, falling leaves, swarm of insects and more. Any object can be set as a particle source (emitter).
  • EcoParticles as EcoSystems: EcoParticles are added to any material like a regular EcoSystem material layer. But with EcoParticles, you get in depth control over the way the particles will evolve over time. You can define the speed, direction, collision properties and duration of life of the particles, as well as subject them to external influences. On top of these new physical settings, all of the classic EcoSystem configuration parameters are used for particle instance population.
  • EcoParticles Effectors: Effectors are special objects that will influence the EcoParticles in the scene. Effects like tornadoes, jittering, attraction, etc. are easily created this way.
  • Automatic Weather Effects - Rain and Snow: These new atmospheric effects enable Artists to create anything from gentle spring rain to a tropical storm, a gentle falling snow to a blizzard, with just a few simple clicks. The heaviness, shape, drop size, speed and falling angle of the precipitation is user controllable. Motion blur can be added if desired too. Weather Effects are available for all types of atmospheres.
  • EcoPainter Improvements: The EcoSystem Painter is completely redesigned to allow even more control and flexibility. You can now create their own brushes using a combination of effectors. For instance, brushes that will resize and align instances at the same time. There are a number of new brush effects to boot, including the ability to lean or rotate instances, raise or lower them, move them around, etc. EcoSystem Instance Selection is now also available in xStream for 3ds Max, Cinema4D and Softimage.
  • Customizable EcoPainter Brushes: Like the brushes in the Terrain Editor, each EcoPainter brush now has its own dialog that displays all of the parameters that can be adjusted. If you want to display a specific brush parameter directly in the main EcoPainter dialog, they can do so with a click on the corresponding Publish icon. The EcoSystem Selection function has been merged with the EcoPainter. This way, you can use the select function to define the instances to work with, directly in the EcoSystem Painter dialog.
  • EcoSystem Fast Population: Vue can now refresh the EcoSystem population interactively, without the need of any re-population action.
  • EcoSystem 360° Population: Vue can now automatically populate EcoSystems from all directions including below objects. This feature works on any kind of object from basic spheres to complex geometry such as rocks, cars, houses... and all applicable EcoSystem settings are supported.
  • Faster Rendering Speed: Significant internal optimizations made to Vue 11’s rendering engine will result in dramatically accelerated rendering especially on very dense EcoSystem scenes.
  • Illumination Caching: This technology lets you re-use GI information over the course of an entire animation thus eliminating the need to re-render the GI pre-pass for every frame. This will dramatically reduce the rendering time of Architectural animations for instance.
  • Many other improvements such as Shared Material layers, Nitrous accelerated graphics core support in 3ds Max, support for latest releases of the Autodesk 2013 products and Cinema4D R14, and more...
Mazak
Google+ Bodo Nittel
ddaydreams ( ) posted Tue, 23 October 2012 at 3:25 PM
One of the improvents says "terrain" I assume terrrain editor.
I was wondering what emprovent the made there.
Anything obviously new in the terrian editor?
Thanks much for info so far.
Frank Hawkins/Owner/DigitalDaydreams
Frank_Hawkins_Design
Frank Lee Hawkins Eastern Sierra Gallery Store
My U.S.A eBay Graphics Software Store~~ My International eBay Graphics Software Store
thefixer ( ) posted Tue, 23 October 2012 at 4:08 PM
Sounds great..
Let's hope it's bug free and tested properly this time round..
Injustice will be avenged.
Cofiwch Dryweryn.
Dale B ( ) posted Tue, 23 October 2012 at 4:17 PM
YAAAAAYY! They finally got the particles working! And this has to be the particle tech that Nicholas Phelps was talking about at Philippe's wedding!!
And I can't be sure, but it looks to me as if the particles as ecosystems, and the 360 generation capabilility, is going to make things like snow falling on barren ground, then building up over time, a possibility.
Mazak ( ) posted Tue, 23 October 2012 at 4:35 PM
Installation was flawless and registration easy. I post some screenshots Ok?
Google+ Bodo Nittel
Mazak ( ) posted Tue, 23 October 2012 at 4:38 PM
Mazak ( ) posted Tue, 23 October 2012 at 4:39 PM
Mazak ( ) posted Tue, 23 October 2012 at 4:44 PM
Mazak
Google+ Bodo Nittel
Mazak ( ) posted Tue, 23 October 2012 at 4:59 PM
Smoke
Google+ Bodo Nittel
Mazak ( ) posted Tue, 23 October 2012 at 5:10 PM
Falling leaves.
Good Night,
Mazak
Google+ Bodo Nittel
randym77 ( ) posted Tue, 23 October 2012 at 6:04 PM
Wow, that looks really cool.
I am still installing.  They sent me a link, but it was 404.  But logging into my account and asking for new download links worked.
Paula Sanders ( ) posted Tue, 23 October 2012 at 7:16 PM
Just tried the Vue 11 briefly on a scene I had been working on in 10.5 Infinite. Two initial impressions. The quick render I did to look at the scene seemed faster and the Ecosystem tools have been changed a lot to give more controls.
Mine also downloaded and installed easily.
martial ( ) posted Wed, 24 October 2012 at 5:14 AM
Falling leaves seems very good. Thank for the screendump
I have downloaded the prerelease but not installed for now
When the final version will com , will i reinstall all again or just copy inside the prerelease folder ??
Mazak ( ) posted Wed, 24 October 2012 at 5:34 AM
The new 360 Eco system.
Mazak
Google+ Bodo Nittel
Mazak ( ) posted Wed, 24 October 2012 at 5:36 AM
@martial Always remove the pre-release, its only good for testing.
Mazak
Google+ Bodo Nittel
scottl ( ) posted Wed, 24 October 2012 at 1:39 PM
 I have Vue 10 Studio and was going to add Ecopainter...I didnt get the email to try 11 and dont see any info on the website (cornucopia). Want to see about the upgrade cost to 11 studio if possible and 11 Infinite. Guess will wait for info, hope its soon.
arrow1 ( ) posted Wed, 24 October 2012 at 4:12 PM
Got my wish for Particles.I hope someone does an easy tutorial on how to use it! Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
thd777 ( ) posted Wed, 24 October 2012 at 4:12 PM
Very cool update! Playing with the Vue11 pre-release. Here is a particle experiment. One particle emitter and collision with a box and ground to produce a simple "waterfall" and "river". The particle system seems very easy to use and powerful. Lots of fun ways to control the effect. Lots to learn...
TD
geekatplay ( ) posted Thu, 25 October 2012 at 2:46 PM
New tutorials (Vue 101, Discovering Vue 11) will be released week after official Vue release. Include  101 tutorials  with covering all new features. Overview and project based tutorials. Be sure check geekatplay site and youtube channel for tutorials.
Free Vue Tutorials http://www.vuetutorials.com
Weekly new releases.
gillbrooks ( ) posted Thu, 25 October 2012 at 4:41 PM
Great 😄  I'm going to need them !
Gill
Terminius ( ) posted Thu, 25 October 2012 at 7:20 PM
Lots of animation stuff but still no true plant editing and procedural erosion. Meh!
Mazak ( ) posted Fri, 26 October 2012 at 10:04 AM
Attached Link: https://www.youtube.com/watch?v=gO6DQjoT8AI
My first particle test video.
Mazak
Google+ Bodo Nittel
geekatplay ( ) posted Fri, 26 October 2012 at 1:38 PM
Add effector( ventelator) to this and watch leaves flow away....
estherau ( ) posted Sat, 10 November 2012 at 9:23 AM
this is in the official vue 11. Genesis pz3 imported into vue is somewhat better.  The keeping poser textures worked and i cannot see the full genesis cage anymore, but the arm is deformed with spare fingers growing from the wrist.
MY ONLINE COMIC IS NOW LIVE
