Mon, Feb 17, 4:25 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
Subject: Pure Velvet Hair on K4 - problem
ObscuroArcanum ( ) posted Fri, 02 November 2012 at 4:41 AM · edited Tue, 04 February 2025 at 9:35 AM
I have Kids 4 loaded, and loading in Pure Velvet Hair everything is fine. I then confirm the hair prop to K4's head, and then something crazy happens with the hair, wrapping around her face like this. I have applied the K4 morph that came with Pure Velvet hair, but it has no effect.
I'm using PP2012, 64-bit version. This is my first image in PO2012.
Anyone know what is happening with the hair, or how I might fix it?
vitachick ( ) posted Fri, 02 November 2012 at 4:57 AM
Hope someone can help u. Right now she needs a haircut real bad..
Win10  Poser 2014/Poser 11 Daz3D
ObscuroArcanum ( ) posted Fri, 02 November 2012 at 5:01 AM
For sure! She is looking more like Cousin It from the Addam's family, than the Alma-esque look I'm aiming for. Didn't have a chance to do anything else, before the hair decided "nope, not going to cooperate"
I'm not sure if it's a K4 issue, with hair or not, because this is the first time I've used the model. I tried the hair on V4 and it behaved itself when I confirmed it to V4's head...
vitachick ( ) posted Fri, 02 November 2012 at 5:03 AM
Maybe it only works with Daz??
ObscuroArcanum ( ) posted Fri, 02 November 2012 at 5:06 AM
The product page says it works for both DAZ and Poser.
And if the hair doesn't work in Poser, then it shouldn't have worked when I conformed it to V4.
The hair looks normal when I load it; it's only when I try and conform it to K4's head that it goes berserk
vitachick ( ) posted Fri, 02 November 2012 at 5:08 AM
Good luck!  Maybe the vendor can help? I'm sure someone will be posting soon to help u with the shaggy dog look problem..
ObscuroArcanum ( ) posted Fri, 02 November 2012 at 5:12 AM
Thanks!
If no one has any ideas in the thread, then I'll shoot off a message to the vendor.
WandW ( ) posted Fri, 02 November 2012 at 6:18 AM · edited Fri, 02 November 2012 at 6:19 AM
There is a fit pose  for K4 in the MAT PureVelvetHair folder.  It looks like a scaling issue....
hborre ( ) posted Fri, 02 November 2012 at 6:26 AM · edited Fri, 02 November 2012 at 6:27 AM
If it is a scaling problem, PP2012 has scaling fix in the properties panel for the hair.  Try activating that.  But, as WandW posted, if there is a fit pose available, you may need to inject that in first before conforming and spinning the dial.
Glitterati3D ( ) posted Fri, 02 November 2012 at 7:02 AM · edited Fri, 02 November 2012 at 7:05 AM
For the K4 fit, you have to use the Prop hair, then use the Translate to position it on K4.
Here, I've used Style 07 after using translate to move the hair into position.  I also used the "Baby Fit" morph to get it a bit more round.
on edit:
Ooops, there IS a fit morph in the Pose folder for K4, but you have to use the Prop hair for it to work.
Glitterati3D ( ) posted Fri, 02 November 2012 at 7:32 AM
K4 fit using the UP fit in the Poses folder.
ObscuroArcanum ( ) posted Fri, 02 November 2012 at 7:53 AM
I feel quite foolish now. I didn't realise there was a second version of the hair included. I was using the V4 prop from the Figures folder, I didn't know there was another option under Hair that the K4 fix was designed for.
Thanks for everyone's help. I've got the hair okay now :D
Glitterati3D ( ) posted Fri, 02 November 2012 at 8:05 AM
Quote - I feel quite foolish now. I didn't realise there was a second version of the hair included. I was using the V4 prop from the Figures folder, I didn't know there was another option under Hair that the K4 fix was designed for.
Don't feel foolish, we've all done it a time or two.  :-)
ObscuroArcanum ( ) posted Fri, 02 November 2012 at 8:10 AM
That is comforting to know!
I am used to Hair props I have bought either being in the Figure folder, or under the Hair tab... I've never had a prop that came under both. I assumed, incorrectly as it turns out, that Pure Velvet with those morphs for the extra characters behaved like other Hairs I'm used to.
Glitterati3D ( ) posted Fri, 02 November 2012 at 3:34 PM
Quote - That is comforting to know!
LOL, look at my first response to you - I did it all wrong.  :-)
It's really easy to miss the fact that the vendor included a Prop hair for a reason.
ObscuroArcanum ( ) posted Sat, 03 November 2012 at 12:38 AM
Absolutely!
But it's all sorted now, so I'm back to making my scene :D
