Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 5:13 am)
Attached Link: http://www.drgeep.com/p4/l2/l2.htm
*(click image to view full size)* *(click link to view tutorial)*Ah, yes, spotlights ... this graphic might help.
Excerpt from the tut at the attached link if you want more info.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
After experimenting a bit with it in poser, it seems that as you increase angle start closer to angle end, it just makes the circle uniform in intensity at a longer distance. If angle start is equal to angle end, it's a perfect circle with no fading out. Is there any real use to angle start other than that?
I usually use angle end and sometimes distance end for spotlights, but what exactly does angle start do? Is this used for any special purpose, or is it best to leave this at 0?
