Wed, Jan 22, 10:59 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 10:04 am)
Subject: A quick question about spotlights
piccolo_909 ( ) posted Mon, 05 November 2012 at 4:15 PM · edited Wed, 22 January 2025 at 10:51 AM
I usually use angle end and sometimes distance end for spotlights, but what exactly does angle start do? Is this used for any special purpose, or is it best to leave this at 0?
geep ( ) posted Mon, 05 November 2012 at 5:36 PM · edited Mon, 05 November 2012 at 5:37 PM
Attached Link: http://www.drgeep.com/p4/l2/l2.htm
*(click image to view full size)* *(click link to view tutorial)*
Ah, yes, spotlights ... this graphic might help.
Excerpt from the tut at the attached link if you want more info. 😄
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
hborre ( ) posted Mon, 05 November 2012 at 5:48 PM · edited Mon, 05 November 2012 at 5:50 PM
Online Now!
Hopefully this link will answer your questions.
Edit: Cross-post
piccolo_909 ( ) posted Mon, 05 November 2012 at 6:16 PM
Thank you! That's exactly what i needed.
piccolo_909 ( ) posted Mon, 05 November 2012 at 6:33 PM
After experimenting a bit with it in poser, it seems that as you increase angle start closer to angle end, it just makes the circle uniform in intensity at a longer distance. If angle start is equal to angle end, it's a perfect circle with no fading out. Is there any real use to angle start other than that?
geep ( ) posted Mon, 05 November 2012 at 6:52 PM
Depends on whether or not you want a "hard" spot or a "soft" spot.
Your choice. 😄
cheers,
dr geep ... :o]
edited 10/5/2019
