Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 7:53 am)
Quote - Load a high resolution texture instead of the default one.
Button on the lower part of the sceen?
how is that going to help with the lighting ?
My Freebies
Buy stuff on RedBubble
It does not change the light, but you can control is a bit by darkening the skin you want to load.
Or play with the skin darkness you load.
Preview in the faceroom is only 512x512, so you will NOT see the details.
And max texture for loading is 4096x4096 => (But will be previewed ad 512x512)
Make a copy of the head texure, resize to 512x512, and darken it a bit.
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
Vilters's solution is the best available - you can't actually change the lighting in the face room preview, as far as I know.
Poser 11 Pro, Windows 10
ok..I was hoping to change lighting. I would think they would want that in future versions. I would think that would be usefull. Anyway...The head I am making is solid color no texture. A light gray. I was hoping the shadow or lighting would allow me to focus on the characters shape without distraction of texture. thanks
How can I change the lighting on the head in the face sculpting area? I am using poser 7.
It looks horrible and blasted to bright and makes head look flat so it is hard to see good results when using the face shaping tool.
thanks
