Tue, Jan 7, 3:38 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
Carrara Free Stuff here.
Subject: Carrara and SSS
mysticeagle ( ) posted Fri, 23 November 2012 at 5:51 AM · edited Tue, 07 January 2025 at 3:36 AM
I see that the default carrara shaders folder has its own SSS shader section. Can anyone tell me whether the Poser SSS shaders that appear in mat poses folders will work in carrara?. I've tried a few of posers basic mat skins and i'm not really impressed with the quality of the output.
OS: Windows7 64-bit Processor Intel(R) Core(TM) i5-2430M CPU @ 2.40GHz, 2401 Mhz, 2 Core(s), 4 Logical Processor(s)  6GB Ram
Poser: Poser Pro 2012 SR3.1 ...Poser 8.........Poser5 on a bad day........
Daz Studio Pro 4.5  64bit
Carrara beta 8.5
Modelling: Silo/Hexagon/Groboto V3
Image Editing: PSP V9/Irfanview
Movie Editing. Cyberlink power director/Windows live movie maker
"I live in an unfinished , poorly lit box, but we call it home"
My freestuff
 link via my artist page
GKDantas ( ) posted Fri, 23 November 2012 at 10:54 AM
No they dont work in Carrara. Carrara use just one color to create the depth, so maps dont worlk in the SSS channel yet.
Follow me at euQfiz Digital
3Drendero ( ) posted Mon, 26 November 2012 at 1:45 PM
Anyone tried to mix SSS channel with Glow or Transparency or something other that may come closer to real SSS map support?
jt411 ( ) posted Tue, 27 November 2012 at 10:24 AM
Here's an attempt I made a while back using the Multi Channel Mixer to get a more desirable SSS effect.
Basically I used a standard V4 shader tree in the first channel, and the same tree in the second, only with SSS and translucency turned on. For the blender, I made a gray-scale map to dictate where the second channel showed through. (Ears, nose, cheeks, etc.)
I don't think I even spent 20 minutes working on the setup, so I'd imagine things could be fine-tuned for much better results. Still, I like this a lot more than the wax-figure stuff I see coming out of Poser 9 :)
3Drendero ( ) posted Tue, 27 November 2012 at 4:16 PM
Nice, got any details to share? Screendumps, numbers, anything?
jt411 ( ) posted Wed, 28 November 2012 at 10:54 AM
I set this up quite a while ago, but I'm pretty sure the tree in the included screenshot was what I used for the final render.
  • Source 1 is a standard V4 setup with no SSS or Translucency
  • Source 2 is a copy of the first tree with SSS and Translucency turned on
  • For the blender map, I started with a standard V4 diffuse map and painted pure white layers over any areas I wanted thee SSS effect to show through. When I was done with the white, I just filled the image background pure black. (This is an area that could be improved by a more talented artist!)
  • For the SSS channel in the second source, I went with a dark red color and turned the diffuse reflection up pretty high.
  • In the Translucency channel, I used Ringo's Reby Sky shaders from DAZ.
  • Rendering time was much, much faster than with uniform SSS
  • I was also able to light the character any way I wanted to without running into the problems that SSS and Translucency usually cause. (Blotches, artifacts, etc.)
Again, I'm sure there's better ways to do this, but it works for me!
jt411 ( ) posted Wed, 28 November 2012 at 11:02 AM
A few more examples from my gallery :)
3Drendero ( ) posted Wed, 28 November 2012 at 11:47 AM
Thanks for the details.
Awesome renders!
booksbydavid ( ) posted Sun, 02 December 2012 at 3:13 PM
Outstanding information!! Thanks.
mysticeagle ( ) posted Sun, 02 December 2012 at 5:43 PM
superb ty
Carrara beta 8.5
My freestuff
