Forum Moderators: wheatpenny Forum Coordinators: Daddyo3d
DAZ|Studio F.A.Q (Last Updated: 2025 Feb 18 8:02 am)
Finally done with this after multiple attempts. After it rendered without the face texture I tried another version with just the top half of the man with plans of just placing it over the first, but forgot to change the file name and wrote over the original. So I eneded up starting the whole thing over again.
Quote - Here's my first Daz/Bryce hybrid.
Built and rendered the landscape in Bryce. Exported the Bryce scene to .hdr and used it as an IBL in Reality to render the figure in the foreground with Alpha channel checked. Then placed the png from lux over the Bryce image in photoshop.
Nice job! How long to do the whole process?
If I were to quibble about anything, it would be that the straps on her dress seem to be too thin. But it's only a minor thing.
Jay
Quote - > Quote - Here's my first Daz/Bryce hybrid.
Jay
I can accept that quibble. I only spent about 10 minutes in Daz, loaded the character, threw on the dress, added the lights and let it go overnight. Already had my settings saved for the skin and hair and used a preset pose from V5 with some minor adjustments.
Don't have a total time for the Bryce work, but it was a few hours a day over 3 days. 3 pieces of terrain that I built and tweaked textures, water was pretty much just drop in and adjust the placement. Most of my time was spent in the Sky Lab. Render time was about 28 hours.
After all that I really wish that the "Send to Daz" function worked so I could have actually placed my character in the scene and not have to Photoshop it. All of the textures came out screwed up in Daz and looked horrible with both 3Delight and Reality. I didn't feel like redoing textures again.
I think the best thing I've learened in Bryce so far is that I can make some nice skies and turn them into IBL's to use in Daz.
Okay boys.. lil' problem here... Not been 'very social' lately, but still hope you want to help me.. gives lovely smile
Anyone had problems with the item "Ultimate Dynamic Tee"? Yes, I can drape it, yes I did 'freeze simulation' (so it's a plain object) but when I press 'Render' in Reality 2.50.1.107 it just stalls.. The render button stays gray and Luxrender doesn't show up.
When I remove the Tee all is fine and Reality and Lux do their job as usual.
I have looked at the files and all I can see is the LXO file stops abruptly here:
AttributeBegin
NamedMaterial "S3_back_55" Shape "plymesh" "bool smooth" ["false"] "string filename" ["12a-Resources/objects/Low V Neck Shirt_Low V Neck Shirt_S3_back_55.ply"]
AttributeEnd
# Object Low V Neck Shirt_5104
AttributeBegin
NamedMaterial "S3_3/4_sleeve_56" Shape "plymesh" "bool smooth" ["false"]
That should not happen, now should it? Every other LXO ends with 'AttributeEnd' and some sort of ply file should be named. Right?
Now you may recognize the item in this 3Delight render.. Help?
Quote - Okay boys.. lil' problem here... Not been 'very social' lately, but still hope you want to help me.. gives lovely smile
AttributeBegin
AttributeEnd
AttributeBegin
In Reality, on the Output tab, change Geometry Format to Lux Native :)
By the way, how come you get younger each time you do a render of yourself?
Oh Anton!! YES!!! That DOES the trick! ..Uhm.. with the render I mean.. :b_blush:
...why I get 'younger each time'?? Well.. that is what I see when I lookie in the mirror.. with my eyes closed, that is..
THANKEE! "Render purrin' like a lil' kitten, though I think you would like the version without the Tee top... grins
Quote - > Quote -
She is cute what model is that?
Agreed, can't wait to see the Lux version.
Regards, Michael
Quote - The Lux difference is proven once again.. I reaaaaly hate to be a critic since you do kick my overall @ss but the hose look a bit too shiny...
That's OK Bob, being critical I mean. You mean the straps from her panties? In that case you are right, I forgot to edit the material. If you mean her stockings I only can say: 'Lycra' :)
I like th glossiness the way it is. In fact there are stockings that are shinier than the ones in Charley's image. BTW, Charley do you have a link to the product that caused the issue? I like to debug it.
Thanks.
Paolo
https://www.preta3d.com
FB: https://www.facebook.com/RealityPlugIn
Tw: @preta3d
G+:
https://plus.google.com/106625816153304163119
The
Reality Gallery: https://reality-plug-in.deviantart.com
Quote - BTW, Charley do you have a link to the product that caused the issue? I like to debug it. Thanks.
It is this one, Paolo.
http://www.daz3d.com/shop/ultimate-dynamic-tee
Quote - ..... was going to say NOT shiny enough.
Same here, not shiny enough, but then again, I like shiny, LOL.
Here is a test image i did to show the versatility of genesis, of which I have become a huge fan!! I recently picked up the Gen 3 iconic morphs for Genesis, mainly because i have lots of Gen adons and wanted to see if they worked with genesis as advertised.
Both figures are Genesis. The female is mostly one of my custom V4 FBMs with some V5 mixed in and the male is mostly custom M4 with some M3 mixed in. The dress is an old V3 one I had that was a one pc with a short, flared skirt. It had a lengthen morph and I liked how it lowered the top part also when lenghtened that long. With a little smoothing modifier, it fit perfectly and i added some custom textures. The tux is an old package for M3 and even the shoes came out better than expected, truly brilliant technology and a huge time saver. I have a real hard time going back to Poser after using such innovation.
Regards, Michael
I just picked up Santa Baby from Daz. I need some help. I can’t seem to make the fur look white. I know it’s probably a really simple fix but I’m not sure what to change. Any help would be appreciated it.
Kim, remove the diffuse texture and set the color to whatever you want. The texture is givin you the color that you have.
Cheers.
Paolo
Tw: @preta3d
G+:
The
[quote Paolo ]
Cheers.
I knew it was something simple! Thank you Paolo!
*hugs
Quote - Okay, here is the Luxrender version. Hope you like it.
Okay.. I'll disregard the model.. your models always look stellar. So, I'm looking at the set itself. Is that a backgrounds made easy set? Being an old-school kind of guy and an architecture student; I LOVE hardwood flooring. Even in my renders. I have a ton of various hardwood patterns, parquets, and grains that have worked great with just about every scene I've put them in. If you'd like, I can zip 'em up and send them to you. I even have normal maps that I've made for the ones I've used(i like the effect nrm maps have on the backgrounds made easy set rather than displacement and bump maps). I, also, have a ton of brick and natural stone textures that make good wall textures as well as a few wallpaper textures. Be happy to share what I have.. they're all freebies. As always, your lighting and composition are impeccable. Once again.. welcome back.
Quote - > Quote - ..... was going to say NOT shiny enough.
Very nice render. Was telling the wife several months ago that I'd like to do a series of renders based on latin ballroom dancing. I love to watch it done by pros.. but suck at the practical application myself. I don't have 2 left feet.. when it comes to dancing.. I have no feet at all.
Very nice image Michael! They both are beautiful!
Quote - > Quote - Okay, here is the Luxrender version. Hope you like it.
The BG is from 'Floors 'n Walls' a freebie from sharecg I downloaded recently.
I share your love on hardwood flooring, but also stone floors are nice to use in a render. I would love to have additional textures for floors and walls (can't get enough of those I think) but only if you are absolutely sure it does not violate any copyright rights if you send them to me :)
Quote - [quote Callad] I just picked up Santa Baby from Daz...
Oh MY! she looks SWEET Kimmers! Now make sure you post the final render!
It's cooking now, I've added a few things and hope it will turn out nice. Fingers crossed.
Should you use or avoid DS public betas?
Here is my humble opinion: http://preta3d.com/blog/2012/12/05/why-you-should-avoid-public-betas/
Cheers.
Paolo
Tw: @preta3d
G+:
The
Quote - Should you use or avoid DS public betas?
Cheers.
I don't think the last official release of DS was ready for release. I'm sure never touching their beta's.
But good post with good points.
Cheers.
It’s better to wait a few weeks more and have the version that has been tested and certified.
And even then it is no guarantee that it is bug free :) But, I'm an addicted technology geek and always try out betas :lol:
Cheers.
Loved the article Paolo! Written with humor (especially the part about the beta-testers) but with much, much truth in it!
Glad that you liked it Charley. Major points for reading it all the way!
Yesterday I had three crowns made, which required 6 hours on the dentist chair. At the eme of the day I was too wiped out to write code so I wrote that piece.
I'm impressed that nobody needed to ask what a xenomorph is :)
Paolo
Tw: @preta3d
G+:
The
Quote - Glad that you liked it Charley. Major points for reading it all the way!
I'll bet Sigourney didn't had to ask either ;)
Nope, she knows it all to well.
Paolo
Tw: @preta3d
G+:
The
Yep, they don't come cheap but loosing your teeth costs even more so I'm really happy that we have this kind of technology and that, thanks to all the Reality users, I can take advantage of it :)
Paolo
Tw: @preta3d
G+:
The
Quote - > Quote - Glad that you liked it Charley. Major points for reading it all the way!
Eating a Xenomorph is childs play, dealing with Sigourney is quite another matter :) Waiting to see Prometheus.
All in good humor inquire, my last "stab" was toward my beloved Apple :)
Paolo
Tw: @preta3d
G+:
The
It is my wish that you all have a Merry and Safe Holiday this year in what ever you celebreate.
It's outstanding. I like the mood, the clothing textures. There's quite a lot that's remarkable here.
Thank you :)
My Rendo Gallery
My DA Gallery
