Forum Moderators: RedPhantom
If you are lucky it will be in the Poser Background render cache or PoserFFRendercache - this in the temp folder of Poser. I do not think it will be in the "normal" rendercache, but you might check it out anyway
But be warned - if you start Poser, usually the temp caches are cleared, so it might be gone if you have started Poser already.
The files are in EXR format - So you need a program that can read these files (like Photoshop or a special HDR viewer)
No idea where the caches are located on the Mac
Using lsof command in terminal shows me the open files are in:
/users//Library/Caches/TemporaryItems/Poser Pro/9/
Theres an icache and a pcloud file in there, that look like they relate to my render, then there's some files in the "BackgroundRender" subfolder under that path...
...which are:
AUX_CAMERA indirectLightPrepass.objs
AUX_CAMERA indirectLightPrepass.xml
AUX_CAMERA subsurfacePrepass.objs
AUX_CAMERA subsurfacePrepass.xml
AUX_CAMERA.objs
AUX_CAMERA.xml
Then there's exr versions of my various textures in a "PoserTextureCache" subfolder.
But all these files look just like the object, texture and IDL, SSS, pre-pass data for my render...
I have restarted Poser already... so it has maybe been cleared :-(
Firefly is still running though...
But can't see a PoserFFRenderCache folder anywhere round there...
Irfanview (free) has a plugin for EXR files, but it may not open a partial...
http://www.irfanview.com/
"Oh - the manual says that? I have never read the manual - this must be why."The exr files are real image files. But in the chache they may well be image files of the different passes. I never looked at them
The posertexture cache files are not your render files, they are the textures your scene used to create the image. Why EXR? Because now the same poser code can handle 32bit textures as well as the 8 and 16 bit ones.
Many thanks guys :-)
I can open exr in Photoshop, so that wouldn't be an issue... at least... if I can find an exr of the render.
Whereabouts are all the recent renders stored usually, under OS X... do you know?
Not sure it'd be in there anyway though, yet?
Still waiting on that find command completing... trawling the disk as I type this.
Okay... found a .exr here:
/users//Library/Application Support/Poser Pro/9/RenderCache/
With filename:
2012-12- 3_23h 7m57s.exr
Looks like it is still being written to... last modified is 21:59 currently (it is now 22:10 here).
Guess I will just keep an eye on that file / leave it till the Firefly process terminates then.
Take a look then...
Fingers crossed ;-)
Timestamp has now changed to 22:44 and the file size has grown a bit. Firefly is still running away, with plenty CPU and Memory utilization.
Well... reckon I will leave it overnight then.
Now - I think the thing is that I asked the D3D Firefly Render script to give me Shadow / Specular and Z-Depth layers, along with the render.
So I'm guessing that probably all this extra data is being compiled into that .exr format file.
I wonder, on that basis, if I will be able to open it?
Yeah, my issue is this render is really a proof of concept using Genesis, in a more content heavy scene...
So far, concept unproven... he he ;-)
Going for it again. This time I was going to try that tip you gave in another thread CaptainMARC... about halving that precalc value in the D3D renderer.
If it bombs again I'm going to give up on it for now.
Or else replace the Genesis figures with V4 or K4...
...althought I'm getting keen to concentrate on some other stuff now.
So, I've had a background render running a while now... a day or so. So not too long. He he.
But Poser has decided to crash out, probably around 80% complete.
Firefly is still happily chugging away, presumably still working on that render.
Is there any way I could retrieve the render once Firefly finishes... if I leave it to do so???
Is the render being written out to a temp file somewhere... I'm guessing it is?
I'm on a Mac...
Many thanks for any help anyone can offer here ;-)
