Sat, Feb 8, 7:26 PM CST
Subject: Render artifact
GKDantas ( ) posted Thu, 06 December 2012 at 6:58 PM · edited Sat, 08 February 2025 at 7:24 PM
Hi people, just testing a new set of textures for Vic4 Bikini and got tose artifacts in the final render. I am not a good Poser user, so i am a little lost now. Take a look inside those red circles, the very dark blue lines dont exist in the texture, but show up in the render...
Follow me at euQfiz Digital
LaurieA ( ) posted Thu, 06 December 2012 at 7:09 PM
Um, the dark blue lines are the shadow inside the wrinkles/puckers in the fabric there at the ring. It's supposed to be there.
CaptainMARC ( ) posted Thu, 06 December 2012 at 7:46 PM
Either decrease shadow amount or increase shadow minimum bias. Or both. Or just change your lighting completely. Or use IDL.
hborre ( ) posted Thu, 06 December 2012 at 8:14 PM
It appears that Shadow Min Bias is set too high on your main light.  There is a lack of bikini shadowing where the material meets the skin.  Try a value of 0.1 for starters.
And just for more complete info, provide which Poser version used and present OS.  We can get a better accessment and recommend an accurate resolution.
GKDantas ( ) posted Thu, 06 December 2012 at 9:25 PM
Hi people, thansk for the answer so far. I am using Poser 2012 in Windows 8 Pro 64 bits.
Looks that the problem is related to the bump channel, when I increase it I get more artifacts.
This light set is an old GI rig, I will try more lights tomorrow, after fight with the bumps that is really different from others like Lightwave or Carrara.
CaptainMARC ( ) posted Thu, 06 December 2012 at 9:41 PM
Ah well, you got the bump self shadowing. Fiddle with shadow minimum bias. I think it has to go up, Superman thinks it has to go down. He's probably right, I'm only a beginner. No matter, try either. If it gets better, try more, if it gets worse, try the other direction.
bagginsbill ( ) posted Thu, 06 December 2012 at 10:48 PM
You have demonstrated, once again, that in Poser neutral bump or displacement is not gray, it is black.
Subtract .5 from the bump map.
