Tue, Nov 26, 3:39 PM CST
Subject: Poser Pro 2010 - Library problem
Vially ( ) posted Tue, 11 December 2012 at 10:01 PM · edited Tue, 26 November 2024 at 3:37 PM
Anyone have any ideas why my Poser Pro 2010 library is no longer showinghte folder icons?
Also, when I select a button across the top, the "selected" button changes to a broken image icon...
This started happening as of today, no changes to system or configuration.
See Attached image for example, and Thanks in advance.
V
infinity10 ( ) posted Tue, 11 December 2012 at 10:18 PM
Check for updates to adobe air as well as for your graphic accelerator card device driver.
Close down and re-launch Poser.
Slide the vertical bar towards the right, so you can see the other broken icons to the right of each content name in the left section.
Click on a broken icon on the right of each content name (not to the left !).  That should refresh the icons for that content folder.  Depending on how large your library is, it may take a while to spawn the icons.
Eternal Hobbyist
Vially ( ) posted Tue, 11 December 2012 at 10:56 PM
Thanks Infinity, graphic driver is up to date, adobe air needed updating, however this has not resolved the "broken" Icons.
Other ideas?
bagginsbill ( ) posted Tue, 11 December 2012 at 11:43 PM
Those category icons are from the old UI long before Poser Pro 2010.
If I were to guess? You copied an old runtime on top of the current one. If so, you should re-install.
Never - ever - copy Poser runtimes onto newer versions.
Vially ( ) posted Wed, 12 December 2012 at 9:38 AM
Yeah I was thinking a re-install might resolve... BIG hasstle, but may be the only resolution...
Now, think it might work to re-install over the top of the current installation? Hate to think the 20+ gig of contant has to be gone through... AGAIN :D
hborre ( ) posted Wed, 12 December 2012 at 10:06 AM
You shouldn't be installing/copying content into the application runtime anyway.  Linking is the recommended option.  Reinstallation should only replace application files, everything else should be safe.
Vially ( ) posted Wed, 12 December 2012 at 10:07 AM
thanks hborrre - going to try the reinstall... :::Sigh:::
Vially ( ) posted Wed, 12 December 2012 at 11:42 AM
Re-install resolved it, thanks everyone, I appreciate the feedback
edgeverse ( ) posted Tue, 18 December 2012 at 12:17 PM
I wish poser didnt have that countdown library thing going on.
3D Digital Comics & Art/My homepage
http://www.edgeversemedia.com
wimvdb ( ) posted Tue, 18 December 2012 at 12:51 PM
Quote - I wish poser didnt have that countdown library thing going on.
Turn OFF "Reopen Folders" in the library preferences
edgeverse ( ) posted Wed, 19 December 2012 at 10:05 PM
Quote - > Quote - I wish poser didnt have that countdown library thing going on.
Whoa, thank you.
Bothellite ( ) posted Sat, 22 December 2012 at 10:05 PM
My resources were not appearing in Poser Pro 2012 -- all of a sudden. It said to dowload the latest version with a link that didn't work very well..  on the troubles went.
If anybody is having trouble updating Flash player there are some real problems updating in both IE and Firebox.  I searched and searched, Googling and Bing'ing...
This install worked FINALLY, after all kind of "time out" failures.
This install does not depend on Active X.
http://ezref.info/Download+Timeout+at+12%25+when+downloading+Adobe+Flash+Player.html
