Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
Check for updates to adobe air as well as for your graphic accelerator card device driver.
Close down and re-launch Poser.
Slide the vertical bar towards the right, so you can see the other broken icons to the right of each content name in the left section.
Click on a broken icon on the right of each content name (not to the left !). That should refresh the icons for that content folder. Depending on how large your library is, it may take a while to spawn the icons.
Eternal Hobbyist
Those category icons are from the old UI long before Poser Pro 2010.
If I were to guess? You copied an old runtime on top of the current one. If so, you should re-install.
Never - ever - copy Poser runtimes onto newer versions.
I wish poser didnt have that countdown library thing going on.
3D Digital Comics & Art/My homepage
http://www.edgeversemedia.com
Quote - > Quote - I wish poser didnt have that countdown library thing going on.
Turn OFF "Reopen Folders" in the library preferences
Whoa, thank you.
My resources were not appearing in Poser Pro 2012 -- all of a sudden. It said to dowload the latest version with a link that didn't work very well.. on the troubles went.
If anybody is having trouble updating Flash player there are some real problems updating in both IE and Firebox. I searched and searched, Googling and Bing'ing...
This install worked FINALLY, after all kind of "time out" failures.
This install does not depend on Active X.
http://ezref.info/Download+Timeout+at+12%25+when+downloading+Adobe+Flash+Player.html
Also, when I select a button across the top, the "selected" button changes to a broken image icon...
This started happening as of today, no changes to system or configuration.
See Attached image for example, and Thanks in advance.
V
